Question about Radio Communications
Sound coming through my speakers
I installed a cb radio in my jeep, i can talk and hear fine (with my car stereo off) when i turn the car stereo on, a horrid squeel comes through my speakers, when i key the mic. im stumped
  • 39 Answers
That is normal especially with stereo's without alot of filtering,but there are a few things you can do to try to alleviate some of it ; move your c.b. as far away as you can like maybe mount it on the transmission hump.Don't have the positives connected directly to the battery.Don't have your antenna close to the speakers,and while were talking antennas make sure your swr is low.If none of this helps think of it this way some people pay big $$ to have talkback in their radio you have it for free also though this is probably more important MAKE SURE all your wire connections are good ( no frayed wires ) . Good luck Dan
Posted on Jun 27, 2009
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals?
Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
Jun 28, 2014 | Connex Cx-366ce Night Runner 40ch Cb...
Lost the FM signal this morning, AM still works fine. all I get is static on FM with some intermittent what sounds like CB radio.
hello please check the rear of the radio as antenna could have come away from it hearing sounds like cb radio do you mean transmissions can you hear someone talking ,its probably someone near you that you are picking up
Mar 17, 2011 | Sony CDX-CA750X CD Player
Hi we just bought a new cb galaxy people can hear us we cant hear anything no squelch no talking
Plug an external speaker in the back of radio & see if you can hear anything. Also,you may want to take bottom speaker panel off & make sure the 2 wires coming off speaker are plugged in to the back rightside of radio. These things I would check first.
Mar 15, 2011 | Radio Communications
I listen my self on my car sound system when i transmit
its a fact of life when it comes to CB. Some times you will hear it over the radio if it is on. Happens with mine. There really is no way to solve it unless you replace all the speaker wire in the car with shielded wire.
You are sending out RF. When the AM modulation hits the speaker wires, the act like an antenna a bit. If there is any electrical signal in the wires, from the radio being on, even if the volume is low, and some times even down all the way, the signal in the wire coming from the radio acts like a carrier signal and causes the speaker to resonate to the modulation, giving you your voice on the speakers.
You can try running the power wire right to the battery, but its most likely coming from the antenna.
You probably will not ever be able to get rid of it.
Some cars it doesn't effect depending on the speaker wires, some it does.
I can say that a lot of people have their radio modded so that they can hear them selves over the radio when they talk. its called talk back. This way you can know how your audio sounds.
Think of it this way. You don't have to pay a tech to add this feature.
Mar 18, 2010 | Midland 1001Z 40-Channels Base CB Radio
Truck Radio/CD Player, no sound coming out of speakers
Have you check the mute mode, maybe it is in mute mode.
Jun 01, 2009 | 2003 Chevrolet Avalanche
Transmitting fine, not receiving an single thing..
the problem could still be with your swr . If your jeep is fiberglass at the point where your antenna connects that could be the problem. move it to a point where there is metal to get a good ground plane and you should hear people talking.
Apr 25, 2009 | Cobra 150 GTL DX Base CB Radio
Bearcat 16 channel scanner
try a extention speaker in. is the squelsh turned up. if you cant plug one in try and unsolder the one inside and check with another one. worse case is the audio chip has gone and it is your local repair shop. unless you what to try and save some cash but remember you need a good slodering iron 17watts or less
Mar 25, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
No sound coming back
Is the radio set up correctly? Is the volume turned up / squelch turned down?
If they can hear you but tou cant hear them, try opening the radio up and checking the speaker connections.
Ill need to know the result of those questions and tests before i can help further...
M3ODQ
Feb 02, 2009 | Cobra 29 LTD CB Radio
I can't hear through my internal or external cb speaker
Can you hear static when the squelch is at minimum ?. If you can hear static then tere is nothing wrong with the audio system. If you are sure about the squelch, connect goosd speaker directly to the 2 wires coming from the main board bypassing the speker jack. if there is still no sound then the audio amp chip is defective. The audio amp can only be damaged if the output is shorted for a long period of time.
Mar 02, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
