Question about Lowrance GlobalMap 4800 GPS Chartplotter Receiver
I have a GlobalMap 2000 with a SAM-1 (not SAM-SD). When I purchased the boat, both a speed/temp sensor and a sonar transducer were install on the transom, but the cables were both cut. I have been able to purchase both the sensor and tranducer, but I cannot determine how to plug in the speed/temp sensor. After 45 minutes of being on hold with Lowrance, the support person said that I needed the SAM-ST to use both. Is this true?? and if so, why would the previous owner have both mounted?? -Joe C
  • joe_cracchio Jun 25, 2009
    1. The main display unit is working
    2. The maplink is working
    3. The SAM-1 unit works now that the cable has a transducer hook to it
    4. Where/how do I plug in the speed/temp sensor?? or can I use a speed/temp sensor?
    I have read the pages noted, but as you can see the pages refer only to SAM-ST and not SAM-1. Do you have available reference material for SAM-1?
    Brigadier General:
  • 8,619 Answers
Hi
Please see this link and check page 6 to 9, it will explain you how to connect the Speed/Temp sensor with your Global Map200---
GlobalMap 2000
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 25, 2009
  • Rylee Smith
    Rylee Smith Jun 25, 2009
    Hi
    Please check the previous link to all the the refrence.
    Thanks
    Rylee
    Sergeant:
  • 296 Answers
Hi
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
All transducer connections are sealed and a cable failure would mean replacing the entire transducer and cable. The only thing I can think of that would cause a simultaneous failure would be possibly a screw from some other installation that happened to pierce both cables at the same time.
Is the SAM-ST getting power? It should have an LED indicator that lights up when turned on. If it is on make a note of what color it is and how it is flashing. Usually green indicates a working model, and some other color represents some kind of internal failure.
Thanks for contacting Fixya
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
My lowrance elite 4 HDI goes black when i get on plane so my backtrack feature doesnt work
The speed of your boats travel only directly affects your sonars ability to read the water depth.
your backtrack feature is GPS based. These is not affected by your boat being on plane.
Your screen being black sounds like your sonar is losing bottom contact due to air bubbles passing under the transducer. This is a common occurrence with most boats.
Add some details regarding what your seeing and we can help you get a better handle on your difficulty.
May 24, 2015 | Lowrance Boating
Does the x510c have a speed and temp transducer or just the paddle seperately
Hi Rick
There is only one transducer. for speed/temperature. From page 2 of the owner's manual (see link below)
"A single-frequency with built-in temperature
sensor is packed with the X-510c"
Hope this helps and happy boating!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/X515cDF_X510c_0151-451_120406.pdf
Mar 10, 2015 | Lowrance X510c 5" Screen Color 200 Khz...
Y cant i mount my structure scan transducer on the bottom of the boat
This is what the manual says:
The StructureScan transducer can be mounted on the transom,
jackplate, step or directly to your boat's hull.
When mounting it directly to the hull, you must purchase a high-
quality, marine grade above- or below-waterline sealant/adhesive
compound.
Jul 20, 2014 | Lowrance LSS-2 Structure Scan HD Black Box...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
I have just bought a LSS for my boat .On the transom i have already a transducer for my HDS and also a speed wheel .my question is can i remove the speed wheel and put my side scanner next to the HDS...
well if the side scanner is a stern mount. Then opposite side would be best and scanning away from other transducer. Too much wattage and they will mix signals and give you two blank screens. You can mount together but run one at a time. Aloha
Feb 09, 2018 | Lowrance LSS1 StructureScan Sonar (Lss1...
My Structure Scan display is good on the left side and the right side does not fill the screen. My transducer is mounted under my boat on the step. I have a HDS8 and everything is brand new. All other...
verify cable harness integrity at base connection of transducer , replace cable or check settings easy fix would be change display unit if unit under warranty as replacing transducer is not easy and economical
Jan 17, 2018 | Lowrance LSS1 StructureScan Sonar (Lss1...
Sonar only reading the surface
First, ensure that the transducer face is pointing down when the boat is level in flat water. You may want to do this step like a tv antenna, adjusting the angle of the transducer while watching the screen.
If that doesn't work, then try moving the transducer further into the water and repeat step one.
Sonar systems are (largely) directional, and will work best when parallel with the seabed (or lake bed etc)
Jan 20, 2018 | Lowrance LCX-104C
Globalmap 2000 sonar not responding
Aug 04, 2008 | Boating
Lowrance Globalmap 2000
The screen is the weak point of the 2000's.  I have one myself, and without warning a number of "lines" appeared on the screen, getting progressively worse over time.
Perusing other forums, it seems we're not alone.  Unfortunately the only "solution" I've found thus far is to purchase a new head unit (eBay is a terrific source!).
May 08, 2008 | Lowrance GlobalMap 4800 GPS Chartplotter...
Open Questions:
Lowrance GlobalMap 4800 GPS Chartplotter Receiver Logo
139 people viewed this question
Top Lowrance GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
