Question about Saitek PZ30AU Keyboard
Hi just reformated disc to get rid of sticky keysand it is still controlling my keyboard. can't type and if I left click it clicks several items. No Numbers can be typed unless I wait for awhile while holding the page key. Ijust want sticky keys gone. It doees not turn off, nor is there an off button. I have unchecked the shoorrt cut key and this is not helping either. What to do?
  • teamworksjz Jun 25, 2009
    Look none of the suggestions worked. The regiustry seems to reset itself to 2 rather than 506 after I open stickyKeys . Evything still sticks. By the way I do not have a Windows CD I just reformateed off my HArd Drive. It seems that I have no Sticky keys listed in the accesibility options when I look to uninstall windows compnents.
    How to fix this thing??? Verge of suicide.
    President:
  • 1,383 Answers
Go to control panel then add remove program then you can see on left side "add remover windows program"
then check details of accessary and utility.
then simple if you want to uninstall any thing from there just disablwe check box then give next.
Posted on Jun 26, 2009
    Sergeant:
  • 296 Answers
Disable Sticky Keys on a Default Installation 1. Press SHIFT 5 times consecutively. The StickyKeys box will pop up.
2. Click Settings. Accessibility Options pops up.
3. On the "Keyboard" tab click the "Settings" button in the "StickyKeys" section.
4. Uncheck the items in this window and click OK.
5. Click Apply and OK on Accessibility Options.
To learn more about StickyKeys and other Accessibility Features open Help and Support and search for "StickyKeys" or "Accessibility"
Well, here are some tips on how to get rid off STICKYKEYS:
1st tip:
Simply pressing in quick succession the shift key five times will enable or disable the 'stickykeys'.
2nd tip:
Go to CONTROL PANEL, click on ACCESSIBILITY OPTIONS, under KEYBOARD TAB, uncheck 'USE STICKYKEYS', click on StickyKeys SETTING, uncheck USE SHORTCUT and uncheck all options under NOTIFICATION - Makes sounds... and Show Stickykeys status on screen.
3rd tip:
Go to CONTROL PANEL, click on ADD/REMOVE Programs, look for stickynotes application and remove.
4th tip:
If the other tips still doesn't help, there might be some leftover registry entries and you may want to seek the help of registry mechanics http://www.pctools.com/registr y-mechanic/?ref=rm_aha.
Or you can personally remove it in the registry entry:
[HKEY_CURRENT_USER\Control Panel\Accessibility\StickyKeys ]
"Flags"="506&qu ot;
5th tip:
Try checking if the key is stuck or partially stuck or there must be a need to clean the keys.
6th tip:
Try connecting another keyboard and see if the stickykeys will prompt again, if it stopped, therefore there is a problem with the keyboard. Buy a new one!
Here are some links to help you in getting rid off stickykeys:
http://www.winguides.com
http://www.5starsupport.com/fa q/keyboard.htm
http://www.senit.org/quicktips /totw_stickylogon.htm
Good Luck...
Thanks for contacting Fixya
Posted on Jun 25, 2009
How to download to memory stickfrom computer?
You could try inserting stick into USB port on side of computer and see if anything pops up to give you any options. Just an idea.
Nov 26, 2015 | Cameras
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
    You might have "sticky keys" so try this:
    When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
      • Press the "Shift" button five times in a row to turn off sticky keys.
      • Open the "Start" menu and then click "Control Panel."
      • Click "Ease of Access Center" from within the Control Panel window.
      • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
      • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
      • Click "Apply" to save your changes and then click "OK" to close the window.
    Hope this helps. Good Luck!
    Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
    Samsung shift buttons are disabled
    shift button is broken...get external keyboard for cheap and move on
    Jan 10, 2013 | Samsung R430 Notebook
    How to turn off sticky keys
    Since you did not post an OS, I will post the steps for Windows Vista (should basicly be the same steps for any windows computer). Click on start, Control Panel, Ease of Access, Ease of Access Center, and the click make the keyboard easier to use. Sticky Keys should be on the list and you can disable it from there.
    hope this helps
    Apr 04, 2012 | Compaq Computers & Internet
    SHIFT KEYS NOT WORKING PROPERLY
    Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
    If you have problem, let me know.
    Good luck.
    Thanks for using FixYa.
    Jul 27, 2010 | Acer TravelMate 2480 Notebook
    Nothing works keyboard locked ? please help on-screen keyboard only
    Hello Friend, Hold shift down both left and right shift key at the same time (do this for several seconds), it somehow solved the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut.
    Hope this Helped you..Thanks for Using FixYa..
    May 08, 2010 | Computers & Internet
    How do i change the speed of the type on the keyboard
    Sounds like you have sticky keys enabled..follow these steps:
    Step 1. Click Start, select Control Panel
    Step 2. Switch to Classic View if not in Classic View Already
    Step 3. Open Accessibility Options
    Step 4. Click on the Keyboard tab, and clear the "Use Sticky Keys" check box.
    Step 5. Click Ok, and Ok again to exit.
    Apr 20, 2010 | HP Pavilion dv8000t Notebook
    I wish to uninstall My Start toolbar and get rid of it a my homepage. Thank you.
    To disable all unwanted start up items in vista, please follow the mentioned steps-
    1. Click on the Vista start icon in the bottom left corner of your screen.
    windows_start_logo.gif 2. Type MSCONFIG in the search box and then either press enter on your keyboard or double-click on the MSCONFIG program that appears in the search results.
    Or, if you're already logged into Vista as an administrator, you may see a box asking you if you would like to continue.
    4. Once you have successfully passed through Microsoft's User Account Control roadblock, Vista will launch Microsoft's System Configuration Utility. Click on the Startup tab.
    4. This takes you to a page with a list of "startup items." Startup items are programs that are automatically loaded every time you turn on your computer. Some startup programs are absolutely necessary, others are simply a waste of RAM.
    Please uncheck the ones that you don't want.
    2- To change home page in Internet Explorer, please follow below mentioned steps-
    2. Type inetcpl.cpl in search and hit Enter key.
    3. Click on tools tab and select Internet options.
    4. Click on General tab and select use blank under home page.
    5. Click on apply and then OK.
    The home page would be blank.
    Mar 21, 2010 | Microsoft Windows? Vista Home Premium...
    Shift key locked keyboard out, can't use keys
    I found that if you hold down both left and right shift key at the same time (did this for several seconds), it it will solve the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut..hopefully this will help you and other people that have had this problem.
    Sep 10, 2009 | Dell Dimension 4600 PC Desktop
    Saitek PZ30AU Keyboard Logo
    Top Saitek Computers & Internet Experts
    micky dee
    Ajay Virvan
    Ajay Virvan
    Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
