Will fire an run but pops through the exhaust from left to right which coil is which number an to what cylinder
SOURCE: electrical- no fire @ plug honda crf 70 2006 year
run wire from one side bolt to other side and try again if it works coil is bad did you replace plug and check gap?
SOURCE: honda 1986 vf400f nc13 engine front two cylingers not firing help
If the spark appears to be weak only for the two front cylinders, then I would suggest checking the electrical connections for the ignition coils.
If the spark for the other two cylinders looks the same (yellow), then I'd suggest checking the compression on the non-functioning cylinders. A compression reading of 140~160PSI is what you're looking for. Low compression indicates internal engine damage - or could be from something relatively simple - like insufficient valve tappet clearance.
If the bike has been sitting for a long period of time, it could be that the carburetors are plugged up with fuel varnish. This can cause some cylinders to not run. A complete carb disassembly and clean-out will be needed.
Testimonial: "thanks for that feed back . there is plenty of fuel and compression is non existant on front left and 80 psi on front right,I suspect cam wear????"
SOURCE: firing order
Hi and welcome to FixYa,
For and MC22, seated on the bike, the left hand ignition coil fires cylinders 1 & 4 while right hand ignition coil powers 2 & 3 cylinders.
Good luck and thank you for asking FixYa.
SOURCE: 1985 honda VT 500c shadow one cylinder when engine hot
how do i check the cooling fan to see if it is any good
SOURCE: my 83 GL1100 goldwing will
first try cleaning the carbs, new spark plugs and adjust valve clearances, new oil and clean air filter, before any screw adjustments, which will need some vacumn gauges attached to set the carb sync
