Question about Technics SA-DX930 Receiver
When playing music or watching a movie, after a couple minutes, the sound stops and the receiver says overload. Is this a cheap fix or will it be more expensive than just buying a new receiver???
  • jose0328 Jun 25, 2009
    Is this a cheap fix
  • 30 Answers
Check to see if the receiver is properly cooled.
Sha'ul
Posted on Jun 27, 2009
All of my speakers work when listening to music, but I noticed when watching a movie my left full speaker and surround sound speaker is not playing
There's only 2 things then that can cause this. First look at the simplest thing, and that would be your audio output connection. If you are playing music from the same playback device that you also watch a movie from; the problem indicates that there is something wrong with the left output that you are using for movie playback. Check that connection on both ends, that it is connected firmly and has no sign of damage and that it is also plugged into the proper input connection on the receiver. If that is not the case; i.e; you have made a single digital connection and are enabling that digital output then the problem is more complex and involves the processing of the digital signal either by the player, or by your receiver. In which case the problem could be isolated to which device is the culprit by connecting it to another device that can perform the same surround sound decoding functions. Making the repair however is not something I know how to do.
Jan 03, 2015 | Audio Players & Recorders
ONKYO Tx SR608 GOES TO "NO SIGNAL" WHEN PLAYING MUSIC DVDs. Not in movies though
that sounds strange. your receiver is not that smart to work out the differences between movie and music dvd. more info would be good.
Apr 09, 2014 | Onkyo Audio Players & Recorders
My pioneer overloads and cuts out
this unit draws alot of power if you have too many things plugged in on the same circuit then it will shutdown and reset itself. unplug reciever and plug straight into the wall
Nov 13, 2011 | Pioneer SX-315
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
I've been experiencing audio and video problems for the last few weeks and have tried just about everything to resolve this matter. I'm able to play all music in wmp or watch downloaded movies but I'm...
you need to update your codecs.  a codec is a Coder/decoder hence the name.  the file is coded at one place and your computer has to decode it.  First off you have to find out what file isnt playing correctly be it a divx, and avi, an mpeg, an mp3 , an mp4 , a wav...... and on and on.  once you figure out wich one is messing up do a google search for the codec.  example divx = bad then search "divx codec download" and follow the links till you find one you can download.  scan it for virus then install.
should fix the problem.
Dec 05, 2008 | Computers & Internet
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
May 23, 2008 | Technics SA-DX930 Receiver
Marantz Sr8500
Check the speakers impedance. it should be greater then 6ohm otherwise you overload the system. Also, if the speaker sytem is rated (in Watts) below the amplifier's power it overloads the amp at higher volumes.
Apr 12, 2008 | Marantz SR8500 Receiver
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Oct 17, 2007 | Pioneer VSX-D411 Receiver
Technics SA-DX930 Receiver Logo
251 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
