Question about Kenmore Washing Machines
Not filing up with water my washing machine - Kenmore Washing Machines
  • 15,935 Answers
If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you’ve attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any “Do-It-Yourselfer” can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Hi. Trying to open locked door on a brand new westinghouse WWF1274 washing machine - just installed. Thanks!
Possible child safety lock.
Is the light on under the temp and spin buttons?If so,push those two buttons at the same time and hold till unlock
Also in wash cycle where water is still in the machine,the door will be locked and must first be shut off then turned back on and choose rinse and spin then start to get the water out of the machine.It should unlock after completion.
The manual for this machine is here:
https://resource.electrolux.com.au/Public/File/?Id=27616
Jan 10, 2018 | Westinghouse Washing Machines
Ge profile washing machine files water but want wash
need to change control board, on top ,opens from the back.
Feb 18, 2015 | GE Profile WPRE6100G Top Load Washer
Machine wont fill with water
Does it run through cycles without filing or does it do nothing? If nothing lilely the timer otherwise the water fill valve id defective
Oct 12, 2014 | Washing Machines
When I wash a full load when it gets to the rinse cycle it only files a quarter of the way, is this the way it works. My clothes are not immersed in the water during rinsing.
Yes, if it is a HE washer it is energy efficient, less water and electricity. It recirculates water over clothes during the wash and rinse.
Sep 02, 2014 | Whirlpool Washing Machines
What happen while washing and draining ok,but not spinning?
Check and replace the spin clutch solenoid ,they get water on them and seize up.
Aug 31, 2014 | Conia Washing Machines
Simpson encore 503 washing machine
Hello:
The first thing to check is at the water inlets, normally these have screen in them. If the screens are clogged no water will flow.
Jan 07, 2014 | Washing Machines
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
Maytag Neptune wash machine. Clogged detergent compartment
This may not help much but here is the Maytag Neptune installation and service manual.
You may be able to better troubleshoot your problem with this.
It's a PDF document that may take a couple of minutes to load.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
Sep 28, 2009 | Kenmore 43142 Front Load Washer
Wft-852a washing machine not filing up with water
have you checked the inlet water valve on the back of the washer?try setting it water temp on all the setting and see if anything happens,try unplugging it to and see if it resers its self,let me know-mike
Oct 08, 2008 | LG Washing Machines
Water Draining off Automatically
Sounds like you have a siphoning problem. Click on the following link for instructions on how to determine if this is the case:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
If this is not the problem, or if you need further advice, please post back and let me know. I hope this helps you.
May 22, 2008 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
