Question about Microsoft Wireless Optical Desktop Comfort Edition
Keyboard stopped responding...changed batteries, restarted computer, but no connections
    Champion:
  • 220 Answers
Have you tried resyncing keyboard and pc.
Posted on Jun 26, 2009
  • Reg Chandra Jun 26, 2009
    have you tried resyncing keyboard and pc.
After restarting my computer the cursor stopped responding to the mouse.
You're probably running Windows, and that's a common problem, and usually very easy to fix. If you are using a wireless mouse, remove the USB receiver, wait 10 - 20 seconds and put it back in. If that doesn't work, remove USB rec. , shut off mouse and go through a restart. Try restarting with them removed, if it doesn't work, try restart with them in and turned on. You can use keyboard commands to do this next part If that doesn't work, go into the Control Panel, system, device manager, mouse, right click ( lined square to right of space bar ) then properties, reset to default - The windows symbol beside space bar is the start menu, the arrows control scrolling through options or moving the page, TAB changes what the computer is focused on, ALT and F4 closes whatever program you're focused on - pressing it twice will cause a restart. And if your comp ever jams up, press CTRL, ALT and DELETE at the same time, opens task manager and unjams,,, usually. Hope some of that helped. Grimm
May 01, 2015 | Computers & Internet
Logik LMWLPP13
I would still try changing the battery. Even if the light in the mouse is still visible, the battery voltage may have dropped.
Feb 26, 2014 | Computers & Internet
Keyboard is not responding it does sometimes then stop again
Step 1
  1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
  2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
  6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
Nov 15, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Keyboard stopped working. Changed batteries and
Does ther del have an external remote module that is connecter to the computer where a standard mouse and b connects. see if the connection is there anything here is possible
Jul 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Mx3000 stopped working, read forums, reset receiver now dashes only when pressing any key. rebooted computer ... now keyboard not responding agian
I got a used MX3200, got the mouse working right off, but no keyboard. This solved my problem: with the wireless mouse working took out the keyboard batteries, pressed connect button on the receiver, replaced the keyboard batteries, pressed connect button on the keyboard. Voila!
Feb 03, 2009 | Logitech Cordless Desktop MX 3000...
Mouse not responding.
I take it that you have a wireless mouse.
Myself I prefer the ones that plug into the console.
Jun 18, 2017 | Micro Innovations KB1045LSR Keyboard
Stoped functioning
Normal 0 Turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
If your having trouble with the mouse also,
turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Dec 03, 2008 | Microsoft K5100141 Keyboard
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Mouse stops responding randomly
The issue may not necessarily be with the mouse. Are you able to use the keyboard once the mouse freezes? If you not even able to use the keyboard, there is some application installed on your computer or a virus due to which the mouse freezes. If, in case, the keyboard works even though the mouse is stuck, try changing the USB port or try a different mouse. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Logitech Optical Wheel Mouse M-BT58...
Microsoft Wireless Optical Desktop Comfort Edition Logo
166 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
