Question about Dell Inspiron 1525 Laptop Jet Black
I have a Dell inspiron 1525 that I just replaced the keyboard and palm rest. When I replaced the palm rest the cable on the upper left top came loose and therefore my speakers don't work. Where does this cable reconnect? I can't see where. Thanks
  • Dell Master
  • 2,404 Answers
Here is the service manuul for the 1525 laptop:
http://support.dell.com/support/edocs/systems/ins1525/en/SM/speaker.htm#wp1180768
It shows you the speaker assembly and exactly where to hook up the speakers to the motherboard so they are functional.
Posted on Jun 27, 2009
    Problem Solver:
  • 16 Answers
Http://printer1.blogspot.com/2009/02/dell-inspiron-15251526-service-manual.html scroll down and download the service manual. zip it to its own file. once you unziped it, open the folder and look for the file palmrest.htm
Posted on Jun 25, 2009
N72 white screen death
Often this is a bad or loose cable:
Step 1: First of all, make sure that you first download the manual for your laptop. Simply google your laptop model and you should be able to find the manual for it on how to replace its parts, etc..It is really handy when getting started. Research on the manaul or dell website the cable information and order from dell or newegg or whatever site or store you choose.
Step 2: You tube a video on how to remove the screws for your lcd properly.
Step 3: Refer to the Dell manual downloaded and refer to how to remove screws at the laptop base and how to remove the:
a) Palm Rest
b) Keyboard.
Step 4: Once you remove the palm rest and keyboard you can get to the motherboard with the Video cable connected.
Step 5: Replace cable and re-assemble everything to the way it was.
Oct 31, 2013 | Dell Inspiron 15 Laptop
How to change the keyboard on dell studio xps 1645
You have to remove the palm rest ( the top part that has the keyboard and touch pad) to access the 13 screws securing the keyboard and shield which are underneath the palm rest. This involves removing the bottom access cover, rear caps, remove ten screws that are marked with a small P on base of computer. Remove two screws that are marked with a K. Remove two flat-head screws in the battery compartment. Then flip the system over. Remove the two screws at the top of the palm rest. Pry the palm rest loose with your fingertips, starting at one edge. Flip open the latch on the keyboard ribbon cable connector, and remove the cable. Lift the latch on the touchpad ribbon cable connector, and remove the cable. Remove the palm rest.
Feb 15, 2011 | Dell Studio XPS 1645 Laptop
Where is the battery located
The coin battery in the Inspiron 2200 is located under the palm rest just to the left and above the touch pad. If you are going to do this yourself, first remove the AC adapter and battery.
Remove the hard disk, keyboard bezel (plastic above the keyboard), keyboard, EMI shield (silver piece on the left under the keyboard), mini PCI card, LCD and Palm rest. This is not an easy job for someone who has never taken apart a laptop, so be fore-warned.The coin battery is right under the palm rest, immediately below the EMI shield. Good Luck!
May 09, 2010 | Dell Inspiron 2200 Notebook
My dell inspiron 1525 left click button below my touchpad is very soft and spongy feeling, It actually feels like it is almost collapsed. It is not like the right where you can actually almost hear the...
Palm rest gone bad and needs to be replaced.
If under warranty contact Dell Technical support, to get replacement.
If you want to replace palm rest on your own, check manuals
support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Jan 17, 2010 | Dell Computers & Internet
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
My kid has picked the buttons off my inspiron 1525.i need a pic so i can put em back in the right place
Here is a picture of the Dell Inspiron 1525 keyboard >>>>>>>
Good luck and regards.
Aug 03, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 not turning on
hi. I suspect that you have either a dead battery or just need a reset. unplug the power cord and then remove the battery. wait two minutes and reinstall the battery.
this will reset everything. now try turning it on. if it won't come on plug in the power cord and charge the battery for 30 minutes before attempting to power up.
Jun 29, 2009 | Dell Inspiron 1525 Notebook
I need to install a keyboard for a Dell Inspiron 1525. I need step by step directions
Before you begin, Follow these steps carefully;
  1. Shut Down to turn off your computer. Ensure that the computer is off and not in a power management mode. If you cannot shut down the computer using the operating system, press and hold the power button for 4 seconds.
  2. Disconnect your computer and all attached devices from their electrical outlets. Disconnect any telephone or network cables from the computer
  3. Remove any installed cards from the ExpressCard slot.
  4. To help prevent damage to the system board, you must remove the battery from the battery bay before you service the computer. to do this, Turn the computer over, Slide the battery release latch until they click into place. Slide the battery out of the battery bay.
  5. Turn the computer top-side up, open the display, and press the power button to ground the system board. Now you are ready to remove your Keyboard;
  6. Removing the Center Control Cover, Remove the two screws securing the center control cover from the battery bay,
  7. Turn the computer top side up, and open the display as far as it will open.
  8. Insert a plastic scribe into the indent to lift the center control cover on the right side and ease the center control cover up.
  9. Disconnect the cable from the media control buttons connector located underneath the center control cover. NOTICE: To avoid damage to the data cable connected to the system board, ensure that you do not pull hard when you are raising the center control cover. NOTICE: To avoid damage to the center control cover, do not lift the cover on both sides simultaneously.
  10. Remove the center control cover.
  11. Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
  12. Lift the keyboard and hold it up and slightly forward to access to the media control buttons connector.
  13. Disconnect the media control buttons connector and remove the media control buttons cable.
  14. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
  15. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
  16. Slide the keyboard cable out of the keyboard connector.
  17. Replacing the Keyboard
    1. Slide the keyboard cable into the keyboard connector.
    2. Rotate the keyboard connector latch to secure the cable.
    3. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    4. Press on the right edge near the top to snap the keyboard into place.
    5. Replace the two screws on the top of the keyboard.
  18. Replacing the Center Control Cover
    1. Reconnect the media control buttons cable to the connector below the keyboard.
    2. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    3. Press on the right edge near the top to snap the keyboard into place.
    4. Replace the two screws on the top of the keyboard.
    5. Reconnect the media control buttons connector to the center control cover.
    6. Insert the left edge of the center control cover.
    7. Press from left to right until the cover snaps into place.
    8. In the battery bay, replace the two screws that secure the center control cover.
Apr 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell laptop pointer problem
This is a very common problem for most Dells this age.
You can try this repair if you feel comfortable.
Remove the keyboard by removing the power button bar (just gently pry up from the right side working left)
re-insert the mouse cable which is coming from the pad/palm rest. Re-assemble.
Check if all the screws on bottom of the unit are tight, especially around the palm rest area.
Good luck
Nov 05, 2007 | Dell Inspiron 2200 Notebook
Dell Inspiron 1525 Laptop Jet Black  Logo
216 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
