Question about Kitchen Ranges
Hello my wife ran the self clean feature and it wasn't quite done when she hit the cancel button.Now the oven door won't unlock.
    Problem Solver:
  • 9 Answers
Try switching it off at the mains for atleast ten minutes just to be sure to reset it, maybe that will work?
Posted on Jun 25, 2009
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Nov 20, 2014 | Frigidaire 30 in. Electric Gallery Series...
Accidentally hit the oven clean button while baking
Hello there.
From the manual I got
To Stop Self-Clean any time:
Press UPPER OFF, LOWER OFF or OFF/CANCEL. If the oven
temperature is too high, the door will remain locked. It will not
unlock until the oven cools
Hope it helps/
Sep 23, 2014 | Whirlpool RBD305PD Electric Double Oven
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    My door on the dish washer wont open
    Good luck and thanks for visiting.
    Oct 03, 2010 | Admiral Dishwashers
    We used the self cleaning option and now we cannot get the oven door open. The lever is stuck in lock mode. Can you give suggestion?
    Thank you and thanks for using fixya
    Sep 29, 2010 | Jenn-Air JGW8130A Electric Single Oven
    Door won t lock
    Check if the program has finished and returned to release. If not the latch wont operate.
    Sep 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
    How do I get the door to unlock so that I can restart the washer?
    There are two ways of solving this type of problem, here are the way out to solve it below
    please carefully follow this instruction below
    On these units they have a self resetting device that you will need to activate this is done by unplugging the oven for at least one hour then plugging it back in and wait for 5 min then press the normal cancel button or you might even hear a click sound then you will be allowed to unlock it ok and close the door hope this helps you out or
    IF the self clean option ran for an hour or so, you will have to wait for the washer to cool down before the lock can un-lock (safety feature)
    thank
    you and thanks for using fixya.
    Sep 11, 2010 | Maytag Washing Machines
    How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
    Good luck with this!!
    Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Kitchen Ranges Logo
    104 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
