Question about Zebra Z4M Printer
My Zebra Z4M stopped rewinding the used liner
  • 31 Answers
This could be something simple like not having rewind (peel) selected in the setup menu. Or you could have a bad rewind motor or main logic board. Remove the cover and make sure no plugs have come loose. There isn't an easy way to check the motor or logic board unless you have a spare that you can swap.
Posted on Jun 27, 2009
Hi there i wausing zebra s4m with my printing software and language is epl can i buy z4m and use it pls reply tks.
Yes you can, the S4m and Z4m both use EPL, contact www.lancerlabels.co.uk for pricing and delivery of a Z4M printer.
Home
Oct 24, 2014 | Zebra Z4M Printer
Zebra Z4M won't print whole label
Did u try system restore?It will restore all of ur settings to how they were when it was working...
Oct 08, 2007 | Zebra Z4M Printer
Is it possible for my Z4M printer to automatically rewind rather than going through the menu and manually setting it to rewind each time? It says saving permanent changes but I still have to change it for...
The best way to do this is to set the printer via software. This can usually be accomplished by prepending a "format" to the print job. The specifics for this are documented in the programming guide. This way all of the settings are defined for each print job. This will completely eliminate the need for any "permanent" settings.
Dan
Apr 29, 2010 | Zebra Z4M Printer
Z4M take up spool not working
I loaded defaults, then set it to Rewind, saved settings as Permanent and it worked
Nov 20, 2009 | Zebra Z4M Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Zebra 4 Plus pause botton shows a fast blink when using take-up mode. have to push in peel lever to get it to print. Please help
Are you sure you are not in peel off mode? It is waiting for a sensor change. When you push the lever, you may have triggered this and allow it to print another label. Put the printer in Rewind mode or something else and see if it changes for you.
Apr 20, 2009 | Zebra Z4M Printer
USB PORT FOR ZEBRA Z4M
It will not work with any drivers if you do not have a parallel port. You can get a pci card that has parallel port on it for use with the zebra z4m.
below is a link for the card that cost only $9.99
http://www.gogocost.com/xcart/product.php?productid=275
Feb 19, 2009 | Zebra Z4M Printer
My Zebra z4m plus
in the setup menu there is an option to choose what the machine does on powerup and head close. Yours is probably set to calibrate. Just change that setting to "none". Same thing with the pausing. there is a setting to pause after printing each label. Just change that option.
Nov 02, 2008 | Zebra Z4M Printer
Label Printing stuck in queues
I think your problem comes from your spool server. Check if you can select not to reprint on errors. As far as the error issue is concerned, i need to konw the reason of the errors to help
Jul 21, 2008 | Zebra Z4M Printer
Zebra Z4M Printer Logo
251 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
