Question about Yamaha RX-V663 Receiver
My yamaha rx-v663 stopped sending video signal to my tv
  • Frank Fulton
    Frank Fulton May 11, 2010
    HDMI, Component, or Composite?
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Posted on Jan 28, 2010
Can the Yamaha RX-V663 (7.1) be upgraded to handle 3-D video input?
Long story short... No. Use your 663 for digital audio, Run video direct to TV for BLURAY & or Cable for 3d content. You can still switch all other video sources thru the receiver. Not cost effective. cost more to do it than you paid for it. Hope this helps
Jul 10, 2011 | Yamaha RX-V663 Receiver
Jan 28, 2010 | Yamaha RX-V663 Receiver
Yamaha RX-V663 display is not working
If you have your receiver hooked up to a TV or Monitor, press "Menu" then toggle to section "5" "option menu" and check your "Dimmer" setting "0" is highest. Then check "FL Scroll" and the choice is "Cont". This info is on page 96 in your manual, if you don't still have a copy, here's the link
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
Hope this helps. If you still have a problem, post a comment and I will help you further.
Dec 26, 2009 | Yamaha RX-V663 Receiver
Switching from comcast to verizon fios my rx-v663
This usually means your receiver is not passing the HDCP copyright protection correctly. Try using component cables instead, if your receiver supports it.
Nov 25, 2009 | Yamaha RX-V663 Receiver
Sound no picture, picture;no sound
a panasonic tv will shut down after a short time with no video input. it sounds like the setup menu in the receiver has defaulted and needs to be setup again to coordinate the audio and video signals. ive seen many yamaha menus default. dont let geeks in your house.
Nov 03, 2009 | Yamaha RX-V663 Receiver
Want to add all of my video components to my rxv 663 reciever
The rx-v663 has 2 hdmi inputs, and 1 HDMI Outputs, The way I would run is 1 HDMI in dedicated to the Blu-ray, This will do the audio HD True digital, DTS-HD , then video out to the TV for HD 1080p resolution, On the cable box out do you have an HDMI 1.3? If so sport it to the other available receiver HDMI IN, net the same in/out as the blue ray, minus a 1080p result video which will only happen Blu-ray, cable will result 1080i HD and audio HD will vary with the signal broadcast format.
Feb 01, 2009 | Yamaha RX-V663 Receiver
Tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Jan 19, 2009 | Yamaha RX-V663 Receiver
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 Receiver Logo
152 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
