Question about Yahoo Mail
Can not open PC Game Safe Cracker
I bought a PC game called Safe Cracker. I have it installed and all of my system requirements are correct but every time I try to start a new game it get this error message:
Projector Skeleton has encountered a problem and needs to close. We are sorry for the inconvenience.
Do you have any idea what is wrong?
  • Joy Shannon
    Joy Shannon Oct 02, 2009
    I don't have Vista. I have XP Professional.
It's a Vista problem I think, I'm looking for a crack
Is also the new "safecracker 2006" if you want play it...
Good game =D
Posted on Oct 02, 2009
Hello, I bought the game "Medieval Lords". Then, I set it in my computer successfully. But when I want to open the game, I have this message : i get an error message that reads mcINI.ccp(1599) abort o
Check you have the correct Operating system and that you have the original game. If you are running the game on a machine with Vista or Win 7 you will have problems. Check this link to see if you have the spec required.
Mar 14, 2012 | Avanquest Medieval Lords: Build, Defend,...
The game could not be started
Glad to help YOU!
Please check if the game it was properly installed. Sometimes appears an incompatibility between the operating system and the game drivers/executable files.
It means:
1. or your game requirements are not meeting your system capabilities (not enough RAM, too tight space on disk, etc.)
2. or the game is not designed for your system (game runs on 2-bit and you have a system running on 64-bit/or viceversa)
3. or the game was not correctly installed because you had a corrupted installer (this case try to obtain another installer from a different source for the game).
My best wishes!
Mar 13, 2011 | Computers & Internet
Hi, I have Windows 7 Home Premium 64 bit running on my PC. After installation unable to open Egypt III game. Waiting for your kind reply.. Kind Regards, Vijay
Maybe the computer did not pass the hardware and video requirements for the game to run seamlessly. Check the requirements of the game and make sure that the computer you are trying to install it to passed all the memory, ram, video and sound card requirements.
Mar 06, 2011 | Computers & Internet
I installed the game (pc is running Windows 7), I have more than 1TB of memory left, but when I hit the play button in the pop-up menu all I get is amall bland screen for a second or so and then nothing
Depending on what PC games you have installed, you have to check the system hardware & software requirements ie. CPU, Graphic card, RAM & OS. for the particular game you had installed.
If your system have an intergrated or onboard video card, normally you will not be able to play high graphic eg. FIFA 11
Since you have not provide any info, on your system hardware & what game you installed.
My guess is that your video card does not support the game requirements and normally you get a black screen!! and unable to continue playing the games.
Hope it helps.
Feb 16, 2011 | Computers & Internet
When I start the game a message come and says: CALL OF DUTY WORLD AT WAR/CAMPAIGN/COOP HAS STOP WORKING. I use windows 7.
this is probably due to the fact that your system doesnt have the necessary updates or drivers to run this game properly or an incomplete installation of the game on your hard disk.try re-installing the game and go through the system requirements to see if your system meets it
Oct 21, 2010 | Activision Call of Duty - World at War for...
I installed a pc dvd game in my computer...the problem is, it hangs during the game. is there a step that i missed or have i installed it in a wrong procedure? can you show me the correct steps installing...
There is problem with the installation as there the installation procedure for games or any other software are very simple and straight forward so do not blame your installation.
There can be two reasons why the game becomes stuck
(1)You do not have enough RAM (For instance the game requires 800 MB and your PC has 512MB of RAM)
(2) Your CPU might be slow (like its 800 MHz while the game requirement is 1GHz)
To check this
(1)On the bottom of your Windows there is a task bar.
(2)Right click on it
(3) On the opening pop up menu select "Task Manager"
(4)On the opening window at the top tabs select "Performance" tab
(5)Turn on the game and observe the bar graph behavior of your CPU and RAM and you will easily find out which components of these two are being over used.
If there is lack of RAM or/and CPU you have to upgrade your computer or may be get a newer faster PC.
If you believe that there is nothing wrong with your hardware then check the media of your game. The game software might have corruptions. The DVD might be damaged you might find scratches on the DVD disc when you hold it at a particular angle on the disk.Try another DVD of the same game to arrive up with a solution.
GOOD LUCK !
Oct 11, 2010 | Computers & Internet
I bought a PC game called Safe Cracker. I checked for the requirements and have all of those on my computer. I installed it and it started right up. When I selected new game I got the error message which...
ok so check your computer to c if you realy have all the recomended things go to http://www.systemrequirementslab.com/referrer/srtest and look for the game clik can you run it and wait for it to load up and from there your on your own
Jun 25, 2009 | Computers & Internet
My sister bought this game hoyle casino 3d for her windows 98 they told her it would work in her computer she is not hooked up to the internet we put the dis in and it brings up something about the...
Before buying a game, always look on the back of the box at the bottom there should be system requirments, the game mite not work if the pc does not support the correct requirments.
But what you could try is to reinstall the game and during installation there should've been a mesage asking if you have internet or not, then you ignore the mesage and click no.
Hope it helps!
Nov 04, 2008 | Computers & Internet
About an old NVIDIA GeForce FX 5500 256mb AGP card
Hi Jhacy, there are a few reasons why you're system would freeze when opening a game you want to play.
1. Please check the game requirements needed for PC. You're system must meet the minimal requirements. If you bought this game, the information will be listed on the game box.
If you do not have the box than go to the web site home page for the game & find the minimal requirements needed to play that game. It is not always about the video card. It is also about you're PC system. CPU strength, system memory, size & speed. Operating system, is the operating system updated?
Even over-all system peformance. Run windows system defrag to help you're primary drive re-gain some speed.
2. Make sure you're FX 5500 is using the latest software drivers.
http://www.nzone.com/object/nzone_downloads_winxp_2k_32bit_91.28.html
3. Install microsoft directx 9.0c Click this link to download & install.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
4. Each game will most likely have (Game updates/patches).
Go to the games main web page & download & install any updates and or patches.
5. Lastly, when you first open the game. There should be a section for (Settings). Lower the video settings for the game. Exzample: If you have the video settings set to High, change it/them to low or medium low.
After everything I mentioned above has been run checked, updated & installed & the game still freezes it may be time to call the makers of the game. Every game site has technical support. You can email them with you're troubles trying to play the game. Chances are after doing all the above you may not need to contact the game maker.
Good Luck Jhacy!
Please let me know if this has helped.
Mike
May 13, 2008 | Nvidia GeForce FX 5500 Video Card Graphic...
Graphics card
when you bought a game you just see a label of a cd's they have a system requirements ..if the system requirements of a game is compatible to your computer then you buy that one.if the game is higher requirements than your pc...so i suggest to buy a higher video card and memory to maximize the system requirements of a game....
Apr 30, 2008 | Dell Dimension 3000® Pentium® 4...
Yahoo Mail Logo
829 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
