Question about Compaq Presario 700 470024-192 Notebook
My lwft and right click on mouse pad dos not work
My left and right click on mouse pad dos not work
  • 30 Answers
Go to HPs website and make sure you have all the drivers installed for the "pointing device". Most likely the buttons have just worn out and don't want to work for you anymore. It is possible that the cable from the motherboard to the mouse came loose and is worth looking into. The easiest solution is probably to use a usb mouse.
Posted on Jun 25, 2009
Samsung laptop mouse left button
-If me I'll buy a new mouse.
Good luck
Mai
Jun 16, 2017 | Computers & Internet
Left and right clicks on my Synaptics touch pad won't work
your touch pad had to be replaced (physically mean)
Nov 01, 2017 | Fujitsu LifeBook AH531
The right side of my touch pad control button has stopped working
Did you check the settings for the left and right buttons under the mouse properties. Normally the left should be set on Click and the right should be set on Shortcut. If it's set to NONE then it will be inoperable. Better yet you can click the Default tab for buttons. Otherwise, it sounds like your touch pad needs to be replaced. The immediate remedy to this is to just go purchase a USB mouse and voila, you'll have the ability to left and right click.
Mar 20, 2012 | Toshiba Satellite A205-S4617 Notebook
I cant get my mouse to move on my samsung lapton
It is possible to turn the mouse pad off. On this laptop, the Fn key plus the F10 at the same time should toggle the mouse pad on and off. If this does not help, try an external mouse. If the Fn + F10 key does not work, but an external mouse does, make sure that you have a driver installed for the mouse pad by doing the following: Click start, then right-click on computer (my computer if you are on Windows XP), and click Manage. When the Computer Management window comes up, look in the left hand pane, and click on Device Manager. Then look in the right hand pane for mice and other pointing devices click the tirangle or plus just to the left of mice and see what pops out from underneath. If any of those have a big yellow exclamation mark, then there is a problem with the driver. right-click the problem driver and click Uninstall. Tell it yes, you want to do that, and then, after it is finished, right-click on the node at the top of the right-hand window that represents your computer, and click Scan for hardware changes. make sure you are connected to the internet, and tell it to connect to windows update to find the right driver. Follow the wizard to finish installing the correct driver. If you see something under Mice that has the word touchpad or obviously represents your touchpad, then that means there is a touchpad driver installed. Right click on it, and click update driver software. Make sure that you are connected to the internet before you go any farther. Then click Search automatically for updated driver software. Follow the wizard to finish installing any updated (if any) drivers. If none of this works, use an external mouse (wired or wireless), because it sounds like your mouse pad is broken. If an external mouse doesn't work, it sounds like you may need to get a new computer.
May 08, 2011 | Samsung N150 Netbook
The mouse pad right and left clicks do not always respond
nope! the whole board matrix needs replacing. use a usb mouse
Aug 19, 2009 | Computers & Internet
Both my keyboard mouse buttons act as right clicks
Hi
Access BIOS settings and search for mouse / peripheral settings, you may find one to activate left and right mobo clicks.
Cheers cbacer
Aug 12, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Both right and left click on my touch pad working
go to control panel->key board and mouse settings and then you can edit the settings from there.
Jul 26, 2009 | Dell VOSTRO 220MT E8400/3.0G 2G WVB 160GB...
How to set up mouse pad so it works with touch
Check in the control panel under mouse. There should be a setting to enable tapping. If there is a touch pad icon on the bottom right of the screen you can also right click on that and select options.
Dec 31, 2008 | Gateway MT3705 Notebook
Mouse Pad and Right and Left Buttons
Great job, I myself prefer to use a extra mouse rather then the built in one, if you chose to do this it wont work right away but if you give it a moment to recognize the mouse it will then be functionable.
Jan 04, 2008 | Toshiba Portege M400 PPM40U01000E Tablet...
Compaq Presario 700 470024-192 Notebook Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
