My maytag epic z washer will not wash. You select
My maytag epic z washer will not wash. You select the cycle press start for 1 second and the machine turns off!!!
  • 6,784 Answers
This is a control issue. the chip set on the control or, timer module, are damaged. replacing the control or, timer, will fix this issue.
Posted on Jun 25, 2009
I have a Maytag Epic z, electric. They dryer turns on but not heat
Instructions
Dryer
Examine the household fuses or circuit breakers if the unit is not working, as the Epic z dryer uses more than one circuit or fuse. Replace or reset as necessary. Use a power outlet with 240 volts or more, which you can determine with a volt meter.
Close the Epic z door firmly and press the "Power" button for at least one second if the dryer has power but isn't working. If there is no heat, verify that you selected a heat dry option.
Look inside the dryer for objects that may have fallen out of pockets if there is a clicking or thumping noise. Examine the drum edges and remove items if possible. Separate pieces of clothing inside the dryer if the items got tangled together, and reduce the load size if necessary.
Tighten the legs on the dryer if the unit is rocking side to side during use. All four legs should touch the floor evenly. Adjust as needed.
5
Press and hold "Start" if a "PF" (power failure) error code appears. If the code persists, press "Power" and then a new cycle selection.
6
Contact Maytag for help if an error code with an "E" and a number appears on the display.
Washer
7
Ensure the Epic z washing machine is plugged into a grounded three-prong outlet if it doesn't start. Shut the lid firmly and press a wash cycle before selecting "Start." Select "Start/Pause" if an error code appears on the display and unplug the unit for several minutes. Reconnect power and choose a new cycle before pressing "Start."
8
Verify that the hose connections are tight on both ends and only high-efficiency (HE) detergent is being used if the washer is leaking. Do not open the washer lid during the wash cycle, as water can deflect off items and splash out of the washing machine.
9
Select "Rinse and Drain/Spin" if the door does not unlock. This removes any excess water from the washer tub. If "Add a Garment" is illuminated, select "Start/Pause" to unlock the door.
10
Verify that you placed the correct detergent in the correct dispenser if the dispenser is clogged or is not dispensing as expected. Wipe out the dispenser drawer with a damp cloth and dry it before adding the correct detergent.
11
Leave the door open after use (if small children and/or pets are not present) if the washer smells badly. Place a laundry cleaning tablet, available at grocery and hardware stores, into the washer and set the washer to the highest temperature wash possible to clean the unit.
Both Units
12
Set a piece of 3/4-inch plywood under the washer or dryer (or both if stacked) if the machine is thumping or vibrating or the floor seems too weak to support the unit(s).
13
Tighten the feet on the unit and make sure all four feet are level on the ground if there is vibrating or thumping during use.
14
Do not connect the washer or dryer to an extension cord, as extension cords cannot supply the power necessary for the unit(s).
Jan 09, 2013 | Dryers
How much it cost to fix maytag washer epic z After I push Power, My Maytag epic z front load washer is turning itself off as soon as I press the Start button!
Press the button on the far right next to the Off button and hold for 3 seconds. I think it's the "Cycle End Signal" button.
Dec 02, 2011 | Washing Machines
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
My dog locked the control panel on my epic maytag washer
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Service Manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 04, 2011 | Maytag Washing Machines
The control lock button is showing on my maytag epic washing machine how do i turn it off
press and hold the END OF CYCLE button for 15 seconds, the problem should be resolved ..
Feb 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
F71
Select POWER/CANCEL twice to cancel the cycle.
Select DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START/PAUSE.
If the problem remains, schedule service.*
Jan 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
I hit cancel in the middle of a cycle and now it keeps saying F1
From the maytag website:
To remove the error display, press Power/Cancel or Pause/Cancel twice.
If Power/Cancel or Pause/Cancel does not work:
Re-select the cycle and press Start/Pause.
Sep 24, 2009 | Maytag EPIC MFW9700S Front Load Washer
I can't start my washer machine, it is in the controlled lock and will not let me do anything else.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Apr 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Control locked
Look under the END CYCLE SIGNAL button- the directions say to hold button for 3 seconds to lock/unlock control.
Feb 28, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
