Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
WATER DRIPPING INTO REFRIGERATOR AND FREEZING
I HAVE WATER DRIPPING INTO THE REFRIGERATOR. THE WATER IS FREEZING IN THE VEGETABLE BIN AND UNDERNEATH AND ALSO IF SOMETHING IS LEANING UP AGAINST THE WALL IN THE REFRIGERATOR IT WILL FREEZE ALSO.
    President:
  • 2,976 Answers
Chances are, your doorseals are shot. This will allow excessive moisture into the unit.
Posted on Jun 25, 2009
Water is dripping under the vegetable bins and freezing
your setting are to high try to raise the temp setting a little this is condensation that's freezing
Aug 27, 2012 | Samsung RS2630SH Side by Side Refrigerator
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water under vegetable bins, no water in drip pan under refrigerat
If this is a top mounted freezer the drain under the evaporator in the freezer section is iced up. You will need to take the back panel in the freezer off, to get to the evap. Defrost the ice with boiling water, then a heat probe will need to be attached to the defrost heater and down through the drain hole, There is a kit for this procedure.part # 819043
Jan 27, 2009 | Kenmore Refrigerators
My refrigerator is leaking;inside. Water puddling under the vegetable bin. There is no drip tray underneath (?) and i cannot find a drain either. Its an older model; freezer on top...it says inside the...
on the back wall towards the bottom, you should see a gulley with a drain hole in the middle. it is this that is blocked. unblock with something flexible shoved down it
Jul 05, 2008 | Whirlpool Refrigerators
Refrigerator has water underneath vegetable and fruit bis. It seems like an air flow situation
We found that the drainage for the defrosting was plugged. The water from the freezer drains from a hole that's on the top of the fresh food unit. There's a gutter that shunts the water to a tube that runs to a tray underneath the refrigerator. The tray was bone dry. So we unscrewed the gutter from the top of the fridge, and yes, it was plugged. Some Scrubby bubbles later, the plug was done. We reinstalled it, and now we don't have water underneath the vegetable/fruit bins.
This is for the GE TBF15DC For other models, your mileage may vary.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
425 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
