Question about Philips CDR775 2-Disc CD Recorder
What can I do to get a disc to play on the left side?
Left tray says no disc-no matter what ,What is the solution?
Clean the with a q tips.
Posted on Oct 06, 2011
  • joe budan Oct 06, 2011
    clean the laser with a q tips
    President:
  • Philips Master
  • 1,779 Answers
Replace the Laser Pick UP Assembly, if you can find one.
Posted on Jun 25, 2009
Can the DVD player be played while on it side.
Yes it will play on it's side after the disc has been clamped in the player. If the disc tray is not designed to be upright then the disc will fall out when you open the tray
Sep 09, 2014 | Cyberhome Televison & Video
When i turn on my xbox and go to xbox live the box where it shows the game you have in. mines blank and i put any game in, doesnt matter what kinda game or anything and it says reading..............then...
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Or Click here to download repair guide
Jan 03, 2011 | Microsoft Xbox 360 White Console
I have the open tray error...Warranty expired,so i figured i'll take out the dvd drive (benq).. Take the cover off and adjust the left pot screw just a hair to the left..Now i can hear the disc spin and it...
  • Note Use ONLY water to clean the disc.
  • Once the disc is clean, load the disc into your console and see if the disc plays.
  • Dec 22, 2010 | Microsoft Xbox 360 Console
    My xbox keeps scratching all discs and wont play them.also tray is loose .when disc is in the screen says reading then makes a noise then says open tray
    Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
    Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally required to restore disc laser burn damage back to "As Good As New Condition".
    For further help on Xbox & Xbox 360 disc repairs, visit:
    www.discREPAIR.ie
    Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
    If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
    You should contact Microsoft for assessment and guidelines.
    Hope this Helps!!
    Apr 02, 2010 | Microsoft Xbox 360 Console
    Xbox 360 disc drive problems.
    There could be a couple of causes, and there could be a couple of solutions. The solutions may not be too fun though.
    First possible problem:
    1. Your discs could be scratched. If that's the case, clean them off as best you can with a soft cloth and all that. If that's not the case......
    2. It could be that your disc drive is messed up.
    If 1. didn't solve your problem, than here are some possible solutions.
    1. Your lens could be dirty, in which case you can try a lens cleaner (probably not the problem)
    2. For many with this problem, formatting their hard drive (yes their hard drive, not disc tray) solves the problem. Unfortunately that's a major bummer because you'll lose everything on the drive.
    3. If you're brave enough to go through the second one and it still doesn't solve it, you're going to have to send it in for repairs cause it looks like the disc tray is going kaput.
    As a side note, for those rare occasions when you do get it to work, try installing the game(s) to your hard drive, this way it won't be so reliant on the disc.
    Best of luck man :)
    Nov 29, 2009 | Microsoft Xbox 360 Console
    Xbox360 disc drive
    Hi, it sounds like you have the" open tray" error that is very common with the 360s. How you fix this is you take your DVD drive apart and look at the laser assembly, there are 2 screws on the side of it, look at the one on the left. Turn this screw to the left a VERY little bit at a time and keep checking it every time you turn it until it stops the open tray error.
    Aug 17, 2009 | Microsoft Xbox 360 Console
    How to open tray when it don't want to open
    You can manually eject the tray, you have to take the faceplate off to do this, but here is the instructions:
    http://www.llamma.com/xbox360/repair/manual_eject_xbox_360_dvd.htm
    Aug 11, 2009 | Microsoft Xbox 360 Console
    Disc does not spin
            This problem shows that the lense of your Play Station reached at its end. You have to change the with new one.So, replace the optical lens and enjoy the games again.
            Thanks and happy gaming :)
         Bye
    Nov 20, 2008 | Sony PlayStation 2 (PS2) Console
    TDK DA 3826 disc tray not functioning
    Is the motor spinning to try to open the drawer?Can you hear it? Can you get something under the tray edge to try to 'help' it out when pressing eject?
    Jan 05, 2008 | TDK DA-3826 2-Disc CD Recorder
    Tray Opens and Closes Repeatedly After Disc Jam
    check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
    Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
    Philips CDR775 2-Disc CD Recorder Logo
    320 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
