Question about Vehicle Parts & Accessories
After batery died alarm dont work
It took me a couple of days to figure out that i left my keys in my truck and after geting into it i found my battery dead and after charging it the python alarm wil not respond. I dont know what model the alarm is i dont have the manual since the old owner is dead i cant ask him. so how do i get the alarm to work?
    Problem Solver:
  • 10 Answers
Get a new one
Posted on Jun 25, 2009
I left my keys in the ignition for a couple hours & when I came back to my 2001 ford taurus and took them out my alarm went off.. I couldn't start my car it was dead.. So not I stuck with a dead car &...
try this it may work put key in ignition and turn to number 2 ( lights on dash) press the fob button on the key. doors should lock, then turn back off to 0, then press the fob button again the doors should open then try to start engine. if all works again but the alarm keeps going off randomly, the power sounder battery may be flat, it can be charged when the system is working again. but sometimes it can get damaged. and it may need to be changed. as I dont know what the sound is coming from under you hood Im thinking it could be this.
Nov 07, 2013 | Cars & Trucks
2007 is250 battery died, then was fully chared, now the car isn't detecting the key and won't start
all new cars are set up that if the battery deads it goes into lockout mode. it is so the dealer ships can make money
Dec 16, 2012 | 2007 Lexus IS 250
Every time I open the door nad drive the car, then shut it off the alarm goes off and I can not find a way to shut it off. How do you do it? I also do not have the key fobs.
quickest way i know of here is providing its a factory immobilisor and not a boy racer add on then take the chip out of the key and tape it under the shroud next to the transponder ,This way the car thinks its got the key in and this will stop the alarm
Mar 12, 2011 | 1998 Cadillac Catera
I have a cobra alarm on my motorcycle.I left the lights on and the battery died.now i hav no spark and the bike wont start.can u help?
HI, SOUNDS LIKE THE IMOBILISER HAS NOT TURNED OFF, YOU HAVE NOW RECHARGED THE BATERY, I WOULD THINK THAT THE BATERY INSIDE THE ALARM UNIT IS ALSO FLAT, CHECK THE FUSE FITTED TO THE ALARM HARNES
, IT COULD BE YOU HAVE DISCONECTED A WIRE OR BLOWN A FUSE WHEN REPLACING THE BATERY, RE CHECK ALL CUT OFF SWITCHES, SIDE STAND IN THE UP POSITION, AND ALSO TRY RESETING THE IMOBILISER
Jan 10, 2011 | Harley Davidson FLHRI Road King...
2005 Dodge Durango v8
replace the batteries in the remote,reset alarm system, then try.
Jul 13, 2010 | 1999 Dodge Durango
Motor does not fire but did this morning before i took it out
well most likely you fried the control module .hooking battery up backward even for a couple seconds will do it .
Mar 08, 2010 | Boating
Two function keys & the 7 key have died the past - Motorola Razr
if u know minor repair remove the cover and key pad clean it and fix it as it is then it works.....it help a lot....
Dec 05, 2009 | Motorola Mobility RAZR V3
1990 camaro was bought 3 weeks ago has a
I believe it is electrical, and someone,
1.Has tried to bypass the use of the correct ignition key,
2.Or a fusible link for the starter is blown.
Does the ignition key have a chip on the side of it? The 1990 Camaro uses an ignition key with a resistor on the side of it. (Chip)
I had a guy install a radio, cut many wires, then wired it up wrong.
I found fusible links in the engine compartment that were blown, and wires that weren't hooked up correctly.
Took a couple of days, plus the wiring schematic for the engine compartment, and interior, to figure out what he had done!
My suggestion would be to find out if the ignition key fits THAT car first. (Dealer info)
Find out if it's the correct steering column.
Then look under the engine compartment to check out the starter wiring. You'll need 1990 Camaro wiring diagrams.
The prior owner bypassed the ignition switch with that push button momentary switch, because either/or a fusible link has melted through, or it is the wrong ignition key. (And maybe a different steering column complete with key switch!)
The 'Chip' on the key is a resistor, and THE correct resistance is needed to bypass the theft deterrent system.
Sep 04, 2009 | 1990 Chevrolet Camaro
Car would not start. headlights work has battery
IF CAR DONT CRANK CAN BE THAT BATERY IS EMPTY, STARTER OR IGNITION SWITCH. IF ALARM SISTEM IS ORIGINAL TRY THIS: CLOSE ALL DORS AND HOOD, TRUNK AND LOCK AND UNLOCK PASENGER DOR WITH KEY. THIS RESET THE ALARM (IF BATERY IS DISCONECTED)
MARKO
Aug 12, 2009 | 1999 Jeep Grand Cherokee
2003 Dodge Ram 1500 won't start -little red light on dash came on
my power locks dont work or heated seats on my 2003 Dodge Ram 1500 i also have keyless remote entry and that dont work i took it to the dodge dealer and they had it for three days and could not find the problem they said the called dodge and did not get a answer please help 93300D6B-4D4D-9E7E-99D8-25B4690C888B 1.03.01
Jan 14, 2009 | 2003 Dodge Ram Maxi
Vehicle Parts & Accessories Logo
193 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
