Question about Kitchen Ranges
My oven display is on F1 and I can not seem to reprogramme the oven.
  • robnglor Jun 26, 2009
    Make is Kenmore elite
    slide in model
  • 126 Answers
F1 code usually indicates shorted touch pad/key panel.need make model for more info.hopes this helps please rate my solution
Posted on Jun 26, 2009
Why when i changed the oven bottom element now it seem to stay red all the time and gets very hot beeping sound and f1 on display
What's ur oven? Ur oven has a heater relay.. K4/k5 relay controlling the heater. It's a small square shape.. Try to trace back the wire..
Jun 08, 2016 | Ovens
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
F1 fault when oven is just sitting.
There are several sufix numbers after your model number so I just picked one, They are often the same as they usually keep the same wiring harness and circuitry through out many.Here's what I've found, Electronic control has detected a fault
condition. Press CLEAR/OFF to clear the display and stop the
beeping. Reprogram oven. If fault remains, record fault number.
Press CLEAR/OFF and contact a Service Professional. See:
https://www.searspartsdirect.com/partsdirect/user-manuals/GLEF396ABA-Frigidaire-Parts-Range-Parts-manual#
or choose from your complete model number:
https://www.searspartsdirect.com/model/search.html?q=GLEF396
Good luck
Oct 30, 2017 | Frigidaire GLEF396 Electric Kitchen Range
When you turn on the oven, display reads CLN or F1.
that means the oven either needs cleaned or that the oven is stuck in cleaning mode i suggest unplugging it for a few hours or clean the oven
Sep 30, 2009 | Amana Kitchen Ranges
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
Range developed problem while cleaning oven
Your electronic oven control is bad and must be replaced.
The clock.
Mar 15, 2009 | Ovens
"F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Dec 18, 2008 | Ovens
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Open Questions:
Kitchen Ranges Logo
182 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
