Question about Canon PIXMA Pro9000 Photo Printer
My canon pro 9000 is spitting ink on prints - Canon PIXMA Pro9000 Photo Printer
  • suzanne98 Jun 25, 2009
    thanks I'll give that a try.
    President:
  • 2,306 Answers
I would start by removing the printhead and wiping any ink carefully from the bottom surface. Next unplug machine while the carriage is in the center, way over on the right is a wiping assembly that wipes the bottom of the printhead. Wipe any excess ink off these wipers with a q-tip or paper towel. Should help...
Posted on Jun 25, 2009
2 Suggested Answers
  • 31 Answers
SOURCE: I installed new ink tanks
Are you sure you haven't confused the new and old cartridges? also make sure that any stickers that protect the contacts on the cartridge have been taken off.
Posted on Aug 21, 2008
Ink smear on back of print job canon pro 9000
control panel - printers- highlight printer but dont select - top right printer preferences - maintance- clean printer heads etc clean with all options available. should fix the problem.
Feb 10, 2013 | Canon PIXMA Pro9000 Printer
Canon Pixma 9000 pro flash 14 times
Hello, this is what your error means: Ink tank not recognized [1684]
A non-supported ink tank is installed (the ink tank LED is turned off). Install the supported ink tanks, check that the chips on the cartridges are clean.
Oct 07, 2012 | Canon Uv Ink Refillable Cartridges For...
I have a canon pro 9000 printer , I have a new printhead how do i replace, is it easy?
Yes its simple to replace the print head follow the steps mention below :
1.Open the top cover of the Canon printer. The print carriage will then move to the center position.
2.Press the tab on each ink cartridge, then lift the cartridges out.
3.Raise the lock lever, then lift the old print head out of its cradle.
4.Remove the new print head from its packing material, then place it into the cradle in the same orientation as the old one had been.
5.Lower the lock lever until it snaps into place, then reinsert the ink cartridges.
6.Perform the Printer Head Alignment adjustment in the printer's maintenance utility.
Jun 26, 2011 | Canon Office Equipment & Supplies
My canon pro 9000 is printing, suddently, in blue and red colors only.
you probobly ran out of cyan and yellow ink or some combination of colors
Jan 13, 2011 | Canon PIXMA Pro9000 Printer
Canon Pro 9000. Used spyder to calibrate monitor and have created profile BUT no matter what I do there is a rosy tone when I print. I use Corel PaintShop ProPhoto for editing and it doesn't matter if I...
Well your Canon has great reviews and it's a shame your is giving you problems!
As soon as possible check the electrical junctions where the Ink CARTRIDGES mate to the PRINTER.
Your printer has half of those connections and your Cartridges have the mating half...
NOTE: Many ink cartridges DO NOT like to be unmounted until they are totally empty... but personally, I would take that chance!
Use rubber gloves and a Q-Tip with a dab of alcohol. Now CLEAN ALL of the pins/connectors so they look like NEW... But don't buff too hard because you don't want to wear the thin gold plating off!
Go ahead and test your printer again!...
If not that ~ take it to a reputable repair center ~ Like GOOD GUYS... and their GEEK SQUAD... but NOT Frys. The "Squad" has very talented field techs... and even BETTER techs in their repair labs too (on the 'business' side of the service counter!).
Major companies RESPOND better to their 'repair centers' with private phone lines, FAST repair part deliveries AND READY telephone experts who backup bench techs (who are) unable to find exotic problems!
Anthony
Dec 25, 2017 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Pixma Pro 9000 Canon Printer is printing terribly colored photos.
You need to check your nozzle check print and see if all the colors print. Also many generic inks are not the right color. Take out your yellow cartridge and see if it's still yellow, if it's orange or brown you need a new printhead, there's a membrane inside that keeps the colors separate and when it breaks you get cross contamination of the colors.
Dec 23, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
I have a Cannon Pixma Pro 9000 Printer. I can't seem to get vibr
some your print head bloked cos of dry ink. just takeoff print head try soak with warm water few minute. carefull not hole print head only to remove dry ink that all
Aug 08, 2009 | Canon Office Equipment & Supplies
Printer spits out black ink and smudges when printed
Your printer apparently needs to be cleaned, using your canon software utility. If the cleaning doesn't help, try to replace cartridges
May 31, 2009 | Canon MX700 Office All-In-One InkJet...
HOW LONG HAS YOUR INK SAT IN THE PRINTER WITH OUT USE AND IS IT A CHEAP INK THAT YOUR USEING ? IF SO THAT COULD BE THE PROBLEM
Apr 05, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
I installed new ink tanks in my Canon Pixma Pro 9000 When I printed a check pattern, the Green (G) would not print. I have tried cleaning anddeep cleaning. No ink at any time.
Aug 21, 2008 | Office Equipment & Supplies
Canon PIXMA Pro9000 Photo Printer Logo
122 people viewed this question
old marine
old marine
