Because this tv is integrated with an NTSC (National Television System Committee) tuner only, you will need a converter box in order to watch television. Also, through my research, I noticed that this television is EDTV-ready (Enhanced Defintion Television, but you need an EDTV tuner in order to increase the picture above SDTV (Standard Definition Television). If you don't own this tv yet, I would advise you to check your options and buy a tv that uses a built-in ATSC (Advanced Television Standards Committee) tuner as this is now the standard on which tvs will be made. All that being said, you may also check with your tv service provider to see if you in fact do require a converter box. I hope this helps.
No, All you will need is a Good external antenna, The good old rabbet ears you may remember from the past. RCA has a geed plat panel antenna for $30 found at most Best Buy, Wal-Mart stores
