Question about Kenmore Washing Machines
My kenmore series 80 washing machine won't drain water. We have checked the hose and that is clear, what should we check next?
  • 6,784 Answers
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 25, 2009
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
Kenmore washer 80 series does not drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump: Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Wont drain water
HI, check the following to address this issue.
2. Water Pump
**The most common issue will be an obstructed hose or, line
Sep 05, 2009 | Washing Machines
My Kenmore Series 80 top loader will not drain and begins the spin cycle then shuts down after a few spins depending on the water level. The machine can only be drained manually. There is no blockage of...
There are many issues that can lead to a no drain situation. check the following areas for faults.
Jun 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series draining problem
Check the following before replacing the timer.
2. Water Pump
Jun 01, 2009 | Kenmore Washing Machines
Kenmore Series 80 agitate for 10 seconds and pause for several minutes
No, the most is a damaged pump, does it pause in agitation or just spin? I would check the lid switch and timer.
Oct 12, 2008 | Washing Machines
Kenmore 80 series leaving soap behind
check for clogs in the output line (the drain hose)
Jun 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washing machine
Marrr
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Apr 06, 2008 | Kenmore 24902 Top Load Washer
Washing machine agitates but won't drain
if it has a filter, check for blocage. otherwise check hose down to the pump and for foreign objects (coins etc) in the pump
Mar 31, 2007 | Kenmore 80754 Top Load Stacked Washer /...
Washing Machines Logo
142 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
