Question about Magnum DeltaForce CB Radio
Lost manual My Q is how do I put my delta on channel 19 ? I was an over-the-road driver and forgot how to do it. any help would be appreciated.
Re: lost manual
Youll also find a download for the Magnum DeltaForce HandBook/Manual at
RIZ , Telford
Posted on Nov 19, 2007
Re: lost manual
The way to change between channell number and frequency display is to press - FUCT then CALL,, slightly longer..
You will also want ur display to show as 33 = for channel 19 uk...27.781..... use the STEP button to split the freqs ..
Hope this helps.........RIZ, Telford
0 characters
3 Points
I have a Galaxy DX44V I need channel 19 only what settings do i put all the switches on ex. high band / low band? e-tone? ect.
Hi, Has this radio been converted to CB? Galaxy 44DX is an import. I am going to say it probably has. Turn the third knob to the right to "AM". And the Fourth knob from the left all the way to the left to "E/E"
Here are two links that will explain it all for you as Galaxy imports are a different breed.
Channel Chart
Complete Guide To Galaxy 44DX
Let me know if this helps. I have a Galaxy 99 and is my favorite. Good luck.
Mar 07, 2011 | Galaxy Radios DX-44V 40-Channels Base CB...
I just picked up a 99 china cobra ltd st. Tx works on all channels, but no Rx on channels 1-19. Any help pointing me in the right direction would be greatly appreciated.
May be bad antenna match on that end. Check SWR at CH 1 and at CH 40. If quite different readings you will need to adjust the SWR and maybe the antenna itself.
Feb 18, 2011 | Cobra 29 LTD CB Radio
somebody tampered with internal adjustors seems to me. you can take a screw driver and turn off receive for so many channels but crank it for higher band. It was probably locked on a upper channel for a Friendly chat station say Channel #28. Where they stayed and talked on 1 channel all time. Could be that. Maybe its got broke wires or board on that other set of channels or parts fried, chip bad etc. Get it checked out at CB shop. if you have any knowledge, turn IF to receive and crank up receive inside radio. If don't know anything take to shop..sounds like simple fix to me.
How do get my magnum cb on 19
Its very easy on this radio because it has a built in frequency counter. I can't remember off the top of my head but its most likely band letter A, then turn the channel selector to 19. If you are on the CB channel 19, the frequency counter will read 27.1850.
If band A channel 19 is not 27.1850 then leave the channel selector on 19 and flip through the band letters until it reads 27.1850. once you have found it, that letter is the CB band. channels 1 - 40 of the cb band.
Nov 15, 2010 | Magnum S6 Base CB Radio
Radio was dropped now the channel indicator is not working no way to tell what channel it's on. its a uniden pc68xl is there a resistor or something to check?
If your lucky, its just the display that is broke. You can buy a replacement on ebay cheap. If its not that, you may have broke something else and you would have to trace it. It would need a tech.
If its still working other wise, just find channel 19. Go near a big highway and check all the channels until you find a lot of truckers talking. Then ask them if its 19. once you find 19, make a mark on the dial and on the radio face in the same spot. then when you put the marks together, you will be on 19. then you can just count up and down.
Each spot on the dial is a specific channel.
the other things to check. If you haven't test transmit on the radio, and just put power to it to see if it still worked, check (if it has them) either the cb/pa switch, and make sure its on CB, because some radio's when you go to pa the meter shuts off, and if you have it check the wx/cb switch. this is for weather. Make sure its on cb again, because again, sometimes this turns off the channel display.
If you haven't hooked it all the way up yet and just to power, you may have over looked that.
I have gotten worried quite a few times working on a radio and not realizing it was on pa or weather.
Fingers crossed. Hopefully you just didn't check the switches.
Oct 08, 2009 | CB Radios
I have a 29 ltd that sometimes transmits at 27.195 on 19 not always hot or cold doesn't matter
Just wanted to let you know that 27.195 is an in between channel between 19 and 20 on this radio. People usually modify their radios to escape the traffic of people to go to these A channels. Its nice and quiet there. Perhaps your channel selector while changing channels is not locking properly to the desired channel. Best wishes to you and hope this helps some.
Jul 06, 2009 | Cobra 29 LTD CB Radio
Cobra 29 delta tune
For normal operation, set this control to the center position.
This feature has several uses and can help receiver operation.
If a received signal is slightly off frequency, the Delta-Tune control can be used to òfine-tuneó your receiver. Fine tuning is accomplished by listening for a more readable signal at the speaker or by noting the Smeter reading when the Delta-Tune control is operated. Another use of this control is eliminating adjacent interference (bleed over from other channels). If an exceptionally high level signal from an adjacent channel is creating interference on the channel being used, the Delta-Tune can be used to minimize or eliminate the interference. Rotate the control until you obtain minimum adjacent channel interference. NOTE: Delta-Tune is operable only in the receive mode.
It doesn't actually help receive any better, just can help kinda like a clairifier.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 19, 2008 | Cobra 29 LTD CB Radio
International use
you need a job that you can travel they work find you just need to travel . now i just came from seattle wa and i ahave one and they work fine it actualy help me when my truck broke down on the road so dont tell me they dont work .I thank haveing one of these is better than a car cb radio lease to you can carry it wear ever you go and conect it to your car or by batter they work well any who have one need to be traveling or working on the road and you have to close to truckers to get answer to get any feed back at lease a mile a way they work in on the instate and the highway so, if you any thing to say about these come on channel 17 i be on that channel in yakima wa and some times on the road or channel 19 ok. see you. handler name jamarhase...
Mar 30, 2008 | Midland 75-785 Handheld CB Radio
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
CB Radios Logo
116 people viewed this question
Top Magnum CB Radios Experts
Are you a Magnum CB Radio Expert? Answer questions, earn points and help others
