Question about Microsoft Windows XP Professional
Windows XP , system goes to sleep immediately after booting.
Now system is showing : Please insert the disk labeled:
Windows Automated System Recovery Disk
into the floppy drive.
Press any key when ready.
  • 674 Answers
CHANGE THE CD OS IF YOU HAVE ANY AVAILABLE SOME FILE NEEDED IF YOU KNOW HOW LOCATE THAT FILE DOES'NT MATTER BUT THE PROBLEM IS YOU DONT KNOW HOW LOCATE..
PROBLEM FROM THE CD INSTALLER
Posted on Jun 25, 2009
Will not re-boot
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP Pavilion dv1000 Notebook
Windows is resuming message
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
You can try this first before the XP repair :
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2009 | Sony VAIO PCG-TR3AP1 Notebook
System keeps shutting down.
If you do not know the administrator password you will need to either go to a technician or reformat and reinstall windows.
Sep 07, 2009 | Dell Inspiron 1300 Notebook
My laptop wont boot up
Hi, a Pc wont boot up beacuse of certain reasons i the Ram are bad or seated badly so pls look on them .
2, your harddisk is corrupted operating system cant start .
Now get operating system cd then try booting with it .
Jul 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Bootmgr is missing
Run a Chkdsk:
OR:
Perform an XP repair:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 07, 2009 | Gateway MT3705 Notebook
Gowthaman
Check if the jumpers on the hard disks are in the right position.
Apr 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to create windows automated Cd
The PC should have come with a set of CDs when you purchased it.
If you don't have these disks you won't be able to do a Windows repair.
Mar 14, 2009 | HP Evo NC6000 1.6 Pentium 4-M/ 40GB /...
The system is getting restart continously,while booting
  • 1. Got to your Start menu and select “Run” option.
  • 2. Type in msconfig command and click OK. The System Configuration Utility program will then open.
  • 3. Select the BOOT.INI tab located at the top of the System Configuration Utility window.
  • 4. UNCheck the box labeled /SAFEBOOT and click OK.
  • 5. When asked if you prefer to restart the PC immediately, or Exit Without Restart, choose to restart the computer manually.
  • 6. Your computer will automatically boot into Windows XP Normal Mode when you will restart it.
Dec 16, 2008 | Microsoft Windows XP Home Edition
Regarding boot failure
If you can boot with a Windows 98 floppy boot disk, then do so, you need to run scandisk. It is also possible that your hard drive has failed, you can go into the bios and see if it is being recognized.
Jul 20, 2008 | Microsoft Windows 98 for PC
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
