Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana SR520S with NO ice dispenser
How do I remove the door TRIMS to change the decor panels?
    Problem Solver:
1. Unscrew the philips screw at the top of the door handle and take off the cap.
2. Go to open the door and your knuckles will be touching a cover panel.
3. Release this cover panel to reveal the screws that hold the door.
4. Unscew the screws to release the door handle.
5. With the handle now off the decor panel can be removed by sliding it out.
Posted on Jun 27, 2009
    Champion:
  • 246 Answers
I also know of a site that sells fantastic decor magnets for your appliances.
Worth checking out.
www.applianceart.com
Posted on Feb 16, 2011
I have an Amana side by side refrigerator. The ice dispenser works but when the ice slides down the chute the little door won't open allowing it to come out.
I believe your Amana DRS2663B Click Here=> 67006000 SOLENOID
has failed and may need to be checked out this is the part that opens the door for the ice dispenser. Click Here=> Amana DRS2663B Dispenser Facade Removal Instructions
As a Whirlpol Technician this is the only way to get to these parts to find exactly what is happening. Should you have other Tech questions I will be here or on our new Beta Fixya Website, Please rate if helpful, Thank You Sea Breeze
Oct 14, 2011 | Amana DRS2663B Side by Side Refrigerator
The ice and/or water won't stop coming out the door when the back soft panel area is pressed. Either ice or water keep coming out when the back is pressed with a glass until door is opened. When the door...
It sounds like the actuator for your dispenser switch is sticking. To fix it you will need to get inside the dispenser housing, which involves removing the decorative front panel on the dispenser.
It's kinda tricky to get this thing apart, and it's even harder to get it put back together if you've never done it. I'd recommend calling a repairman.
Sep 28, 2010 | LG LRSC-26922 Side by Side Refrigerator
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
The ice and water dispenser on my Amana Refrigerator slowly leaks water. Are there repair parts to correct this? And how is the plastic frame containing the dispenser removed from the door?
The problem is most likely not in the door. When the dispense button is pressed it actuates an electric solenoid valve in the rear of the refrigerator that opens and allows the water to flow. Over time the valve seals get worn and the water seeps by. This is what usually causes a drip at the water dispenser. If there is a drip at the ice side then the door is jammed and is not closing fully. This allows the ice at the opening to melt and drip. Hope this helps. Please accept and rate. Good luck.
Dec 08, 2009 | Amana ARSE664BS Side by Side Refrigerator
Bad frost keeping building up around ice dispenser
This is usually caused because the door is not shutting all the way or not tight allowing air in.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Sep 21, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice dispenser in the door
This is about a close as I can come to answering your question. Click on link below.
http://www.applianceaid.com/ken_whirl_disp.html
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 27, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Amana SR520SSide by side fridge freezer: How do I take off the dm
CLICK HERE for a PDF version of your use and care manual.
CLICK HERE for Installation Manual.
Page 3 of the installation Manual has the instructions on removing the doors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
210 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
