Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Touch screen not working
Can the flexible wire be repaired?
  • vasumathir_a May 11, 2010
    my touch creen is not working how can i solve the problem
  • 10,594 Answers
No, that flexible wire will only be replaced. You can have its part number written on it.
Posted on Jun 25, 2009
Touch screen stopped working. Everything comes on but none of the functions on the touch screen work. The picture comes up as do the touch scrren buttons but nothing happens when you push them. The other...
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Oct 15, 2010 | Sony DCR-SX40 Camcorder
Touch screen shows wear and tear
LCD will be replaced as there is no cure for wear and tear on its surface. Required LCD part number is appended below:
A1334748A... FTS BLOCK ASSY (35STMG07)
Available in Sony Parts Store for $154
If you are handy with electronics stuff repair then can replace it easily, remove side and bottom screws and take apart front and rear cabinet of camera. Unlock connector that holds lcd flexible connection wire, remove solder connection of back light source plate from lcd flexible wire, solder back light connections in new lcd flexible wire and insert it in jack on main board of camera.
Local camera repair shop will help you to replace lcd if you feel uncomfortable doing so.
Thanks.
May 19, 2010 | Sony Cyber-shot® DSC-T200 Digital Camera
When I switch on my DCR-HC21E Mini DV there's nothing on the LCD. Just blank. No lights nothing. So I can't use the touch screen menu. Can I fix it myslef ?
Do you hear start up (ding) soundin camcorder? does it eject tape?
If yes, then flexible connecting wire between lcd board and camcorder board is cracked/ broken and need to be replaced.
If you can apart camcorder and have little experience in electronics stuff repair, I can provide you part number of that flexible wire info.
Sep 24, 2009 | Sony DCR-HC21E Mini DV Digital Camcorder
LCD on Sony HDR HC1 not working
This happens when flexible wire between LCD board and camcorder board got broken or cracked.
Camcorder needs that connecting flexible wire replacement, let me know exact model of Sony camcorder if you need part number of flexible wire.
Thanks.
Sep 22, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony hc-32 touch screen won't work
When touch switches become nonworking then mostly its cause of connecting flexible ribbon wires between LCD board and camcorder main board that got cracked so touch buttons signal does not go to camcorder system control. Need to replace that flexible wire by qualified camera tech.
Very rare cases I found touch buttons layer that is pasted and part of LCD becomes defective, do you see hard or deep scratch on LCD surface? if yes, then LCD screen will be replaced because touch button array is damaged.
Thanks.
Sep 16, 2009 | Sony DCR-HC32E DV Digital Camcorder
Touch screen is not working
There is flexible wire between LCD board and camera main board that seems cracked, thats why touch screen buttons does not work.
Replace that flexible wire.
Jun 30, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Touch screen is not responding on my x1
ur TOUCH PANEL IS FAULTY kindly go for warranty claim or tell me i can give u link for the out of warranty replacements
Mar 16, 2009 | Sony Ericsson XPERIA X1 Smartphone
The screen its totaly black
Right, Following is part number of required flexible wire..
" 1-864-761-11 " --FP-185 FLEXIBLE BOARD
It is available in Part Store for $26
Qualified tech will charge approx $100 to fix this camcorder.
Good luck.
Mar 04, 2009 | Sony DCR-HC32E DV Digital Camcorder
LCD touch screen malfunctioned
There is flexible ribbon wire connected between LCD board and camera board. This wire seems cracked / broken.
You need to replace this wire.
Need further info, let me know.
Dec 13, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
LCD Touch Screen
Connecting flexible wire between LCD and main board of camera seems cracked/ broken. Please replace it with new one.
Jul 31, 2008 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
525 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
