Question about MSI 845 PRO Motherboard
Ram upgrade issue msi 845 pro motherboard
My PC does not work properly when upgraded to 512Mb x 3 sdram. It works ok on a single ram but not when 2 or 3 ram installed. It does not boot properly. XP & Ubuntu are reporting a kernel error message that is somewhat related to the memory address. My old pc is a P4 1.5G intel processor on msi 845pro mobo & ami flash bios running on xp pro & ubuntu. I need help with setup. Thanks.
  • rldiscutido Jun 30, 2009
    The PC seems to be working on boot startup. The bios on startup is reporting the extended ram memory installed which is 1535 mb. So I did not touch the BIOS setup. However, I cannot run my PC either on windows xp & Ubuntu properly. For windows, it is reporting some missing files like ntkrnlmp.exe and hal.dll. Now, I attempted to reinstall XP SP3 windows with no success. Again It cannot load files like ntkrnlmp.exe and hal.dll. What is wrong with this RAMs?
    This is the DRAM Timing setting in the BIOS:
    Configure DRAM Timing by: SPD
    CAS# Latency: 3 Clocks
    RAS# Precharge: 3 Clocks
    RAS# to CAS# Delay: 3 Clocks
    Precharge Delay: 7 Clocks
    DRAM integrity Mode: Non-ECC
    AGP Aperture Size: 256MB
    Delayed Transaction: Enabled
    All 3 rams installed are exactly the same with the following description:
    Memory Capacity = 512Mb
    Memory Speed= PC133, 133Mhz
    Memory Type=SDRAM DIMM, 3.3v, CL3.0, 168pin for Desktop PC
    Other Features: Unbuffered, non-ECC,non-Parity, 64x4 high density
    My motherboard is an MSI 845 Pro motherboard (MS-6529 ATX mainboard)
    Any
    Any
    Scholar:
  • 106 Answers
You should check bios for the ram settings, voltage and speed, they will be printed on the package the ram came in.
also, you don't want to mix ram up, they will run at the slowest ones speed.
also, most ram is used in pairs (2 at a time) using the 3, depending on the motherboard will give you errors.
try entering the bios on boot, and set the ram setting properly. you should see something that flashes on boot, like press f8 or del for bios. change your ram settings, save and exit. type back with your motherboard and ram model numbers if this solution did not work.
Posted on Jun 26, 2009
Also, the motherboard will be having specific support for single and double sided rams... You need to check the motherboard manual to know that...
Presoon
Posted on Sep 19, 2009
Fdmdgo-03014s
For a Chaintech 9BIA motherboard;
Motherboard chipset is an Intel 845,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
http://www.firingsquad.com/hw/168/Chaintech_9BIA/
PC133 (SDR Sdram at 133MegaHertz;
{Single Data Rate. The proper term, not just Sdram.
Double Data Rate Sdram is Sdram.
Double Data Rate 2 Sdram is Sdram.
Double Data Rate 3 Sdram is Sdram.
DDR Sdram, DDR2 Sdram, DDR3 Sdram.
Synchronous Dynamic Random Access Memory )
Low-Density, Unbuffered, Non-ECC, Cas Latency of 3
(Don't get some cr@p off of Ebay.
It's usually high-density, ECC, that was used by old server computers)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146305
WHEW! Unless you just want to run 1GB of ram memory, I would toss that board! (Two 512MB sticks) ->
-> Need two 1GB sticks of SDR Sdram at 133MHz
http://www.directron.com/ct128m72s4r75.html
$400 smakeroos USD!!
Bah! That is just cra-zy!
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram memory slot is 1GB.
IF, you only have ONE ram memory module ('Stick'), it goes in Slot 1. (DIMM 1)
That is the ram memory slot closest to the processor socket.
The Processor reads ram memory Slot 1 first.
http://www.cpu-upgrade.com/mb-Chaintech/9BIA.html
Regards,
joecoolvette
Nov 26, 2012 | Chaintech 9BIA (CT-9BIA) Motherboard
1.Suggest me the type of ram which is supported Foxconn 8657MF-series. 2.When i installs DDR400 RAM of 256MB it gives continuous beep(bee-bee-bee) sound. 3.What are the beep codes of Foxconn...
the beep sound on system starting before booting starts refers no RAM in system, if you need to upgrade your RAM then go for DDR-SDRAM PC3200 200MHz 512MB 0r 1GB.
Jan 24, 2011 | Foxconn (865G7MC-ES) Motherboard
Motherboard for compaq pcsr5109uk have upgraded to 1,5 GB this adding a 1 GB ram since doing this pc will not boot up,pc has said that the mother board has died this has only started since new ram have...
From what you have stated, the original ram memory was two sticks of 512MB.
It's PC2-5300
(DDR2 Sdram at 667MegaHertz)
When installing ram memory, and installing two sticks with one stick being larger, the larger stick of ram memory is installed in Slot 1.
This is the ram memory slot that is closest to the Processor.
(The Processor reads Slot 1 first)
On the motherboard it has DIMM 1 printed next to Slot 1.
The 1GB stick should go into Slot 1 (DIMM 1), and the 512MB stick should go into Slot 2 (DIMM 2)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077654&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3457899
Scroll down for the motherboard illustration, and photo.
Won't boot up with the original ram memory installed again?
1) What type, and size of 1GB ram memory did you install?
2) What ram memory slot did you install it in?
3) Did you follow anti-static precautions BEFORE you put your hands inside your computer, and BEFORE you took that ram memory stick out of it's protective anti-static bag?
[Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
You may not even see it, or feel it.
Poof!
No computer.
Computer unplugged from power, computer on a table, computer case open, TOUCH the metal frame to relieve your body of Static.
{A couch, bed, or directly on a carpet floor are HIGH areas of Static]
Before you answer my questions try this;
If the two sticks of 512MB PC2-5300 are still installed, follow anti-static precautions, and remove them.
Take a pencil eraser, and clean the gold plated contact pins on the bottom of each ram module. (Stick)
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(The above example is DDR Sdram, not DDR2 Sdram. I posted the link so that the gold plated contacts are clearly shown.
DDR Sdram has 184 contact pins.
92 on each side.
DDR2 Sdram has 240 contact pins.
120 on each side)
Remove the eraser dust with air. Use a can of compressed air for computers, or air pressure from your mouth.
Reinstall the ram memory modules.
Computer unplugged from power, press the Power On button in.
Hold the button in for a count of Five seconds.
(Count 1001, 1002, 1003, 1004, 1005)
Let go of the Power On button.
Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS back to the factory settings.
Plug the computer back into power.
WAIT 1 minute, then turn the computer on.
I await your findings, and answers to my questions.
Jun 04, 2010 | Computers & Internet
For D845GLLY ,i tried with 512MB SDRAM(Duble side),had booting pb
make sure the ram is working fine just connect to other working system and check the ram are ok .but i m sure this is motherboard problem kindly show it service center or change the motherboard.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | Intel D845GLLY Motherboard
Added more ram but it's not working Compaq E500
what did you mean not working ?? didnt see the new Ram memory ?/ or didnt boot at all ....anyway ...when adding new ram memory ..first thing you do is to remove the Bios battery for to let bios on defaults and let it be able to read the new added unit ....second ...be sure the new added ram is compatible and in the same frequency ,then remove the battery like I said and in the last ...reinstall the operating system ....always look at the boot to see if the ram memory that is displayed is the same value with the one you know that actually is installed on the slots...it should work if this was just an option to make it faster ...and not a wild guess cause it use to have issues and didnt boot before...
Sep 10, 2009 | Compaq Armada E500 Notebook
Tried to upgrade ram with 2 new pc133 sticks of 256mb ea. Didn't work. What's wrong? Are there switches on the motherboard I need to change? Or something else?
No there are no DIP switches to change, or jumpers to move on your motherboard, in regards to your BIOS recognizing ram memory installed.
(BIOS. Basic Input/Output System. This tiny program, {64MB in size usually}, that is burned into your BIOS chipset, is what recognizes ram memory on your computer)
Things to know about the older Sdram ram memory.
1.It's really SDR Sdram. Single Data Rate Synchronous Dynamic Random Access Memory.
DDR is Double Data Rate Sdram, DDR2 is Double Data Rate 2 Sdram, and so on.
Point? All ram from SDR to DDR3, IS Sdram.
2.Standards have been set by JEDEC for computer ram memory starting from DDR Sdram on up. This standards were not implemented back in the day of SDR Sdram.
Point? Ram memory manufacturers didn't all follow the same standard, and ram memory made for one computer, would Not work in another computer.
This means you need THE ram memory for YOUR eMachines computer.
Main factors when buying SDR Sdram,
A.Correct type. You know this. SDR Sdram.
168 gold plated contact pins on the bottom of the ram 'stick'. (82 on each side)
B.Correct 'Speed'. ('Speed' is slang for Frequency Rate) You know this. SDR Sdram that operates at a frequency rate of 133MHz. (Or also known as PC133)
C.It must be low density Non-ECC ram memory. It cannot be high density ECC. (Error Control Correcting. Used for Server computers mostly)
D.Correct CAS Latency. Also known as Ram Timings. 3-3-3-3-2 would be normal for SDR Sdram.
E.Correct Chip Configuration. How the DRAM chips are accessed. DRAM chips are the black rectangular chips on each side of your ram memory 'stick'. Also what size the DRAM chips are in MegaBytes. (MB)
F.What the Maximum TOTAL Amount is for the motherboard. Is it 256MB? 512MB? Or more?
G.What the Maximum Amount is for EACH ram 'slot'. (Correct speak for 'Slot' is Bank)
H.Do you have four ram 'slots'? You MUST have a ram stick in Slot 1. This is the slot closest to the processor. It is the first ram slot the processor 'reads'.
Jul 12, 2009 | E-Machines eMachines Desktop PC
My Dell C600 won't recognize the 2 new 256 mb sticks of RAM
i think you need a same brand of 256 for it to work? and when you buy something for your computer make sure that the one you both is the same brand or code with your 128 for example you have 128 ddr2 sdram so you can only upgrade it with 256 ddr sdran or 512mb,1gb,2gb ddr sdram.
May 01, 2009 | Dell Latitude C600 Notebook
Ram upgrade
you need to make sure the ram is compatable, it looks like an old machine so chances are its using sdram pc100,
check the ram your trying to make sure its not pc133. let me know what each piece of ram has on its sticker
Mar 23, 2009 | Dell OptiPlex GX200 PC Desktop
Memory upgrade not working
It only Accepts two PC–2100 SDRAM memory modules..If both are same then the slot might have some problem...
Jan 29, 2009 | Gateway 450ROG Notebook
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
MSI 845 PRO Motherboard Logo
464 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
