Question about Dell Office Equipment & Supplies
My Dell 1720 printer will print a first page of one short line of icons, then print the actual items sent to printer. As it is printing the status window shows printer off line and no toner level.
  • 3 Answers
Chances are the formatter board on your printer is going out, if it is still under warranty i'd call dell otherwise prob cheaper to get a new one
Posted on Jun 25, 2009
5mm vertical gap dell 1720dn
Any time an imaging drum is replaced on a 1700, 1710, or 1720 model dell laser printer, you must reset
the photoconductor count. The following procedure illustrates how this is done:
1. Open the front access cover
2. Press and HOLD the Cancel Button (Red X)
3. When you see the LED's 'Chase' turn the printer off
4. Close the access cover, and turn the printer back on
5. Press the Continue Button (Green Triangle) to print a settings report
6. Under the section 'Cartridge Information', locate the item 'PHOTOCONDUCTOR COUNT=0K' indicating 'Zero Thousands'.
s now been reset, and you should now be able to print now ok
May 06, 2014 | Dell 1720dn Laser Printer
Dear Mr. / Mrs. , I encounter a big problem with my print server edimax ps 1206U .actually i work in a company that in one of our departments we have a HP color laserjet cp 1215 printer and our OS is...
Most of the print servers (1206u as well) do not support bidirectional printing, which actually allows the computer to printer bidirectionally so that printer info (toner status, print status) is sent to the computer.
Open Devices & Printers
Right Click on the CP1215 and go to printer properties
On the Ports tab, remove the tick next to the "enable bidirectional support"
Apr 26, 2011 | Computers & Internet
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
How do I print duplex on the Dell 1720?
You need to visit the Printer in Control Panel - Printers and double click on the 1720 icon and go through the setup tabs and select Duplex Printing. If you only want to print duplex occasionally you can select duplex from the print options presented when you print a document by selecting the Preferences or Setup button when the Print Dailoig box appears.
Nov 12, 2009 | Dell 5100cn Laser Printer
Printer won't finish 2-sided document
Uninstall Dell All in One Center. Download the laters drivers form http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_PHT_964&os=WW1&osl=en&catid=&impid=
it will fix your problem.
remember to choose the correct Operating System.
Jul 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell 1720 printer prints junk first page with only ?Z@ troofpaN.
This is a issue with the printer drive that windows is holding, not the printer. To Un-install your printer drive the correct way, goto add/remove programs, and un-install the printer there, then open up your printer control panel and right click where there is no printer. In the right click menu click server properties, then click the drivers tab, then remove the 1720/1720dn drivers there. A system restart will be necessary in most cases before it will let you remove the drivers(the Microsoft print spooler is to blame here for that). If this still doesn't work for you, then install a hp laserjet 4 driver and see if it does the same thing. if not, then it is something with the driver/spooler, if so, then it is the MCU of the printer, and you might want to look at buying a new printer.
Jun 29, 2009 | Dell 1720dn Laser Printer
Will not print, printer icon comes on but zero pages to print
numbered_list.gifIn your email program once you send a message it will go from the outbox to the sent items. if there was any problem it would not appear in the sent items box, but would remain in the outbox and would post an error to you.
Now- go to tools,options, receipts tab, and put a check mark in the first box. And send your email as normal. That way when they open the email at their end you get a message that says they opened your email at their end.
please leave rating
May 09, 2009 | Dell Inspiron 530 Desktop Computer
Dell 1720 flashinf replace drum- error.
The second link was the helpful information. Also, to cut through all of that --
If you need to reset the counter:
1. Remove drum kit with toner
2. Make sure all print jobs are flushed otherwise whatever has been sent and not printed will come spewing out.
3. Hold down CANCEL Button until all lights flash through.
4. Slide the drum kit and toner properly into the Printer.
done.
Mar 03, 2009 | Dell 1720dn Laser Printer
Dell 1720 usb port printing problem
You can get a usb adapter to printer comp ports on ebay eBayeBay
Sep 20, 2017 | Office Equipment & Supplies
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
98 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
