Question about Texas Instruments TI-30XA Calculator
How can i enter 3 to the negative 2 power - Texas Instruments TI-30XA Calculator
    Problem Solver:
  • 5 Answers
Hit the buttons in this order:
y^x
You can also find 3 to the second power and then divide the number 1 by your answer.
Since y^-x is the same as 1/y^x
Hope this helps.
Posted on Jun 30, 2009
How to use it for exponents?
To enter exponents (1, 2, 3, -3..) use the general power key marked with Y^x or X^y or ^. Enter the base press the general power key then the exponent. If exponent is negative try enclosing it in parentheses. use the change sign key (-) to enter the negative sign before the exponent.
To enter power of 10, you can use the shortcut key marked Exp (the 10 must not appear when the Exp is used to enter exponents for power of 10).
Feb 24, 2013 | Sharp Office Equipment & Supplies
I need to calculate exponential to the power of a number with minos sign. I have a BA II Plus
Make sure you use the +/- key (located just right of the decimal point key) to enter a negative number. For example, to raise 3 to the -2 power, press 3 y^x 2 +/- =
Jan 13, 2013 | Texas Instruments BA II PLUS Financial...
I when i power -3 to the second i get -9 when it should be just 9
No, is giving you the correct result. When you negate 3-squared, you should get -9. If you want to square negative three, you need to type it in as ( (-) 3 ) ^ 2 or ( (-) 3 ) x^2
There is a difference between (-3)^2 and -(3^2). If you omit the parentheses, the calculator will interpret it as the latter.
If in doubt, use parentheses.
Feb 17, 2011 | Texas Instruments TI-84 Plus Calculator
I am having issues performing a simple function on my TI-30XS calculator. when I square a negative number - I get a negative number as opposed to a positive number?? example -3 - which I specify the...
You're not calculating the square of a negative number, you're calculating the negative of a square. You need to use parenthesis to indicate the square of a negative number.
You're calculating -(3^2), not (-3)^2.
To calculate the latter: ( (-) 3 ) x^2 =
Dec 05, 2010 | Texas Instruments TI-30XA Calculator
Negative log
Use the log function (common logarithm). See screen capture for markings on key.
To evaluate the negative of a logarithm
Enter the number (argument) of the logarithm
Press the = key to have it calculated.
While result is still displayed, press the sign change key or (+/-).
Beware that -log(number) is not necessarily a negative value.
Another way to calculate -log is to use the relation
log(1/a)=-log(a) .
Your example
3 [EXP] [(] [+/-] 2 [) ] [LOG][=] [+/-]
[EXP] is the key to enter exponent of a power of 10 :It is a shortcut, so no 10 is entered. Respect the key sequence above.
[ (] left parenthesis to prevent ambiguity due to the negaticve exponent. Just a security.
[)] is the enclosing right parenthesis
[+/-] is the Sign Change key
May 06, 2010 | Casio FX-260 Calculator
I am tutoring a student who uses the Casio fx-300MS. A problem required that he raise (-2) to the 4th power, and the calculator indicated the answer was -16. I know that the answer should be a positive 16,...
Enclose any negative number between parentheses before squaring.
If you enter -4^2, where - is the negation, the result will be -16 because of the priority rules: exponentiation (power) has priority over negation.
If you enter (-4)^2 the result will be 16, because parentheses have priority over the squaring: the 4 is negated then the result is squared.
Dec 30, 2009 | Casio FX-300MS Calculator
Okay... my Ti-89 isn't squaring numbers right. I put in -2^2 and I get -4, or I put -3^2 and I get -9 and so forth. I thought and still believe that when you square any number, despite whether it's...
You are not using the right syntax. It has to do with priority of operations. raising a number to a power has priority over the negation sign (the change sign key). Th operations you are performing are treated as follows.
1. The square of 2 is calculated first (4),
2. then the negation (change sign) is performed, giving -4.
To get what you intend, namely the square of a negative number, you should enter the calculation as follows.
(-2)^2.
Since the parentheses have priority over everything else, the negation of 2 is calculated first, giving -2, then the power is performed next, and the result should be 4
If you need convincing, here is a screen capture.
Hope it helps.
Oct 26, 2009 | Texas Instruments TI-89 Calculator
Negitive powers
Use the ^ key to insert a power (it's located above the division key) then put a negative power by typing the negative key (located at the very bottom right of the keypad next to the ENTER key) and then the number of the power.
10^-3
If this doesn't give the right result, put the negative power in parentheses. I can't remember off hand if you need to do that or not.
10^(-3)
Jan 10, 2009 | Texas Instruments TI-89 Calculator
How do you enter negative numbers on a TI-30X iis calculater?
On the bottom of the calculator near the zero and the enter key it has the symbol (-) that is a negative number symbol
Nov 22, 2008 | Texas Instruments TI-30XA Calculator
Casio calculator fc-100v, to the power of?
Hello
To calculate a number to an arbitrary power you use the button labeled ^ .
If you want the cube of 2 your enter
[2][^][3] will give you 8. If your exponent is negative use the sign change key (-) and close the negative exponent between parentheses : for exemple the sequence to compute 2 to power of negative 5 is as follows
2[^] [(] 5 [(-)] [)] which means you enter the value of the exponent before the change sign (-). If you use the big MINUS sign you will get a syntax error.
Hope it helps.
Aug 29, 2008 | Casio FC-200V Scientific Calculator
Texas Instruments TI-30XA Calculator Logo
161 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
