Sony Cyber-shot  DSC-W80 Digital Camera
Problem for Sony Cyber-shot DSC-W80 Digital Camera
Turn the power off and on again
By whunton on Jun 25, 2009
Same problem I see a lot of others having. Turn the camera on and the lense pops out 3-4 times with the message 'turn the power off and on again', and repeats each time the camera is turned on. Thank you for any help you can offer.
Best Solution
posted on Jun 25, 2009
Very Helpful)
Cyber Master
Rank: Guru  Sony Expert
Rating: 90%, 96 votes
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
Somewhat Helpful)
jimmyjimjam1
Rank: Wiz
Rating: 75%, 44 votes
take it down to a camera shop like jessops and tell them your problem and see if they can sort it.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sony Cyber-shot DSC-W80
Questions and Unsolved Problems for Sony Cyber-shot DSC-W80
Do you recommend Sony Cyber-shot DSC-W80 Digital Camera?
Answer
Answer
will my sony cybershot dsc-w80 charge with a usb cable
Answer
When I use my zoom to take a pic it tells me to power off and them back on?I have a Sony SteadyShot... (More)
Answer
camera display is not functioning cannot take photographs, screen always show a message to turn off... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital... Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
