Question about Dell Dimension 8200 PC Desktop
I cannot get the tower to start up. I have checked all the connections and i have unpulged every thing. but when I plug it back up no green light just an orange light which does not shut off at all
Check memory is properly inserted if is check to see if the ram is not defective do a google search on some free programs to check for defective memory.Also try eliminating everything by also taking the video card out mouse etc and all other cards and harddrives then try powering it on to see if it works.
If it does then start putting things in one by one to eliminate them as a possibility.
Posted on Jun 26, 2009
    Scholar:
  • 136 Answers
Check if the memory (RAM) chips are properly inserted into the respective slots. Also check the monitor connections once again.
Posted on Jun 25, 2009
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
I plug in cable that plugs in to the back of the tower and goes to the outlet, but nothing happens. The green light in the back does not come on either
Perform a powerdrain of the computer i.e. unplug the power cable from the back of the tower and press the power button and hold it down for 10 secs.
Please make sure that the power cables are connected properly.
try using a different power cable and check it on a different wall outlet.
Best of Luck
Dec 21, 2010 | Computers & Internet
I had a power outage and my computer when I tried to turn it back on after the power was turned back on. All it does is have a green light blink on the back of the tower and a small green light on the...
most likely the surge fried one of your ram chips... this is where i would start first sometimes the ram will work as a surge protection for your motherboard
Nov 18, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
I cant boot up my acer aspire 8000 , only shows a " going to sleep " sign after i try to boot it up
Check if the CPU is connected to the monitor. also check if you find the power light is steady green on the tower. And their should be a green light at the back of the tower
Dec 13, 2009 | Acer Aspire 8000 (91.5A525.U33) PC Desktop
No video
Try to check the light on the monitor. If it is amber, then check the video cable both from the back of the monitor and the tower. Try a known-good monitor. Check the diagnostic LEDS of the tower. There are four of them in the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem. If you have a solid green light on the tower, no beeps heard and no video, check the LEDS. If you get 2-4 light, a possible graphics card failure has occurred. If the computer has an external graphics card, open the tower, remove the card and put it back in. If still persist, try a known-good card. If it still does not resolve the problem, try reseating the memory cards. Remove and put it back in. If still no go. Then it's a motherboard problem.
Sep 16, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Dell Dimension 8200 PC Desktop Logo
118 people viewed this question
Alun Cox
