Question about Mitsubishi WS-65809 65" Rear Projection Television
Ws-6513 error code 13
R5k02 had burnt up and r5k01 was burned so they were replaced along with la4663 and ic3e01.
  • Michael Yohn Jun 05, 2014
    both convergence ic's have been replaced and changed out the fuse although good. have not figured out what a 13 code is for
2 Suggested Answers
SOURCE:
  • 927 Answers
SOURCE: Mitsubishi WS_65413 won't power up??
Good Day Scott;
When resistors and or fuses burn out, it's a sign that some other device was drawing too much current. So, replacing these parts alone will not repair the TV. There could be a couple of things that may have caused this condition. First, look toward the front of the chassis (from back) and look a shiny substance (fluid) on the circuit board. Look very closely! It may be your convergence circuit, most common, IS's. If you are not experienced in repairing TV's, I would call a factory authorized service dealer to have this unit repaired. It will take an expert to repair TV properly.
Sorry I could not give you good news, good luck; Big Irish.
Posted on Jun 21, 2008
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
Ricoh aficio 6513 error code 422
this is a corona leak could be a broken or dirty corona wire
Jan 03, 2010 | Ricoh Office Equipment & Supplies
Tv has no picture and the power button goes off after 5 to 10 seconds. help
Do the self check this set has: when the power light goes off: ON THE FRONT OF THE SET PRESS BOTH THE MENU AND INPUT(or DEVICE) BUTTONS FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
The power light should blink a two digit error code. For example: 2 blinks, a pause and 2 blinks---it will repeat this code several times.
2,2 is the most common and the easy one to fix and know what is wrong.
Let me know the error code and I will tell you what it means.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 23, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Asaad z.essa
Check to see if there is anything stopping the scanner unit from moving freely.  Usually it is cause by a loose screw in the path of the scanner.
Oct 16, 2008 | Ricoh 6513 Copier
Good Day Scott;
Jun 21, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Aficio 6513
the proplem solved by adjusting the the home position of the trans fare belt cleaning unit .
May 24, 2008 | Ricoh 6513 Copier
Ricoh 6513 error code PM CAll
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
Apr 04, 2008 | Ricoh 6513 Copier
MITSUBISHI WT-46805 No Volume
Sounds like audio output IC is bad.Hope this helps. It is on the center circuit board on a little heat sink directly in front of the large Convergence heat sink. It is referred to as IC3E01 and the part number is LA4663. Hope this helps. Let me know if i can assist you further.
Nov 05, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
