Question about LG Dishwashers
3850DD3006A- i start it and then the timer doesnt change  then and its starts beeping after a couple min. and says LE!!!!!!!!
  • 21 Answers
I HAVE HAD TO CHANGE THE MOTOR $100.00 TWICE IN TWO YEARS FOR THE SAME PROBLEM. THE MOTOR HAS A MAGNETIC? RING THAT SPLITS AND STOPS THE MOTOR FROM SPINNING. TODAY THE DOOR ROPE THAT MAKES THE DOOR NOT SO HEAVY BROKE. IT IS FOUR YEARS OLD TODAY.
WHAT A PEACE OF JUNK!!
Posted on Nov 25, 2010
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Error code of three beeps on a whirlpool dryer model 68972981
Hi troy crawford,
Well if it beeps for 3 times and then shut off when you press start it means that the dryer thinks that dryer door is open. You will have to replace your door switch to fix the problem. or you can also try closing the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. many time it will works...
Good Luck
Regards
Nov 07, 2011 | Whirlpool Dryers
Dishwasher makes a buzzing noise and then shuts itself off.
MINE IS A 3850DD3006A AND IS 4 YEARS OLD. I HAVE CHANGE THE MOTOR TWICE FOR THE SAME PROBLEM, IT GIVES CODE LE. THE MOTOR RING SPLITS AND WON'T LET THE MOTOR SPIN EASILY.
Nov 25, 2010 | LG LDF6810ST Stainless Steel Built-in...
How to set oven timer on a GE electric stove
that is not a problem. I copied the instructions straight from the manual which you can also review by clicking here.
Using the clock and timer.
To Set the Clock The clock must be set to the correct time of day for the automatic oven timing functions to work properly. The time of day cannot be changed during a timed baking or self-cleaning cycle. Press the CLOCK pad. Press the HOUR and MIN + or – pads to set the time of day. Press the START pad. Make sure the clock is set to the correct time of day. To Set the Timer Press the KITCHEN TIMER ON/OFF pad. Press the HOUR and MIN + or – pads until the amount of time you want shows in the display. The maximum time you can enter in minutes is 59. Cooking times more than 59 minutes should be changed to hours and minutes. For example, enter 90 minutes as 1 hour, 30 minutes. If you make a mistake, press KITCHEN TIMER ON/OFF and begin again. Press the START pad. After pressing the START pad, SET disappears; this tells you the time is counting down, although the display does not change until one minute has passed. Seconds will not be shown in the display until the last minute is counting down. When the timer reaches :00, the control will beep 3 times followed by one beep every 6 seconds until the KITCHEN TIMER ON/OFF pad is pressed. The 6-second tone can be canceled by following the steps in the Special features of your oven control section under Tones at the End of a Timed Cycle. The timer is a minute timer only. The timer does not control oven operations. The maximum setting on the timer is 9 hours and 59 minutes. To Reset the Timer If the display is still showing the time remaining, you may change it by pressing the KITCHEN TIMER ON/OFF pad, then press the HOUR and MIN + or – pads until the time you want appears in the display. If the remaining time is not in the display (clock, delay start or cooking time are in the display), recall the remaining time by pressing the KITCHEN TIMER ON/OFF pad and then pressing the HOUR and MIN + or – pads to enter the new time you want. To Cancel the Timer Press KITCHEN TIMER ON/OFF pad twice.
If you need further assistance follow up with a comment and please let me know and i will be glad to assist you further. Thanks, Midwest-tek
Aug 28, 2010 | GE JTP20 Electric Single Oven
I have a calypso washer it seems to be stuck on the heavy cycle no matter what i dothe display says 53 mins it wont do anyhting wont start if i hit the button wont let me choose another cycle like quick...
I just ran into a similar problem. Ours was stuck on Normal with 42 min. Started beeping every couple minutes last night after bad rain storm. Couldn't get it to stop. it would turn off if I hit stop and a couple minutes kater (like 2min) it would come on by itself. Left it unplugged overnight until about 6:00pm. Plugged it back in and it wnt right back to the normal mode after about 2min. HOWEVER, I keft it sit with the lid open and it beeped every couple minutes for a while then suddenly stopped. I checjked it and it is off, hasn't come back on. I haven't tried to run a load through it yet, so I don't know if it is fixed or not..
Oct 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
Dishwashers Logo
589 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
