When turned on by the button at the top in the middle, there are only three buttons "on","up" and "down") it shows only the digits "Lo" and those digits disappear in less than a second, weight doesnt
Wht is the solution for this problem?
Thanks,
Idit.
I changed the battery and now when turned on all icons on screen flashing non stopI changed the battery and now when turned on all icons on screen flashing non stop
You can't post conmments that contain an email address.
I have not found a manual anywhere currently because the manual is no longer on Health-o-meters website, only the current supported scale. However, I have one and can tell you what I know on how to operate it.
First Remember you ALWAYS have to tap (slightly touch the middle of the scale to initiate it to calibrate ON to ready to take your weight) the scale and you then wait for the little lines at the top and bottom to flash on and off, and then show a 0 on the scale where the Weight will be once you have stepped on the scale. However, make sure your feet are slightly moist (if you just woke up and your feet are dry wipe them with a moist cloth first) for a good contact on the pads that will send the small signal through one leg and back down to the other to measure your body fat and hydration levels.
For those having problems with false readings or Lo readings after changing batteries (Lo means the batteries are low and to change if you haven't done so), make sure batteries are good even if you just bought them by checking them in a Battery Output checker, which you can get at the store...or check the expiration dates on the battery, things can sit around at the store for a while some times especially at small grocery or convenience stores.
Then if you are still getting false or Lo readings, you need to do a Factory Reset by flipping over the scale and look toward the top where you will see a small hole with raised letters, not colored, that show RESET under the small hole. Get a tooth pick or some about the same diameter and put it in the hole and press the little button. You can feel it when you get the toothpick--- or whatever you are using---in the middle of the button and it slightly depresses. Hold it down for at least a count of "One Thousand one to One Thousand ten," which means ten seconds. That should do it.
Then you need to make sure your settings are set by holding down the number on the front end that you will use to save your data, and hold down the Set/Save button on the top front at the same time. When it starts flashing the 5 for Feet in the Height either change that with the History button by pressing it until you get the correct number or leave it by pressing Set/Save button again. Use the Set/Save button to Save and Move to the next item to Set/Save and the History button to Change the number or item such as Gender from Female (the Default is 5Ft 3in Female who is 18 years of age and the Goal starts out at 100 but you can save a Goal Weight or not by choosing YES or NO then set the Goal if you Choose YES).
The Date and time are set by just holding down the Set/Save button until it flashes in the little yellow box in the bottom left of the screen. Then use the buttons the same way as you did above.
By the way when you see H with numbers after you have weighed Saved (To Save: hit Save while the numbers are on the screen) and once they disappear you just press your number again hit History to Scroll through your history... the H stands for Hydration percentage.
Repeatedly press the self-timer button (the middle button of the three at the top of the back, marked with a one-handed clock) to cycle through the self-timer modes.
If you want to set the time, the button that has a picture of the calendar and clock (just to the right of the arrow key) until it shows the time. Then press and hold the date/time set button (just tor the right of the red minus button) for three seconds until it begins to blink. Then use the arrow key and enter appropriate digits and the am/pm button for am or pm. If you need to set the date, press the calendar/clock button again until it shows either the date or the time, and then hold the date/time set button down for three seconds until it begins to blink. Then use the arrow key and enter appropriate digits.
Make sure you have toggled the switch up at the top. If you see orange on top, flip the switch so that no orange shows. If that is fine, hold down the middle button and the menu button until you see the apple logo when you see the apple logo, continue to press and hold the middle button but press the pause/play button instead of the menu and it should unlock it.
The easiest way to fix this is to do a master reset and let the TV reprogram ll of the channels. You must have the original Sony TV remote to do this. When you have the remote, find the circular area of the remote with four buttons in a circle around a center button.. Turn on the TV and Press and hold the top button (the Up button) of the 4 buttons arranged in a circle. Then, while holding down this Up button, press the power button ON THE TV (not the one on the remote) and release both buttons. The TV should now reset and come up and ask for a language choice. You choose the language using the 4 keys mentioned earlier (the top and bottom of the 4 keys for up and down and once you have the choice you want, press the button in the middle). After choosing the language, it will ask to autoprogram the channels. Choose yes and let it autoprogram and all of the channels should reappear.
push menu middle top button . scroll down to world time on middle 4 way button press OK top right hand button set time with middle 4way button press OK
Hello, if u read the user's manual, there is an option to resync the hands. Goto the units mode ( Press the middle button, and then twice in the center of the screen, so that the digital display shows either 24h Cm or 12h... u get it ) Once in that press and hold the middle button for 5 seconds, until the display shows SYNCHRO. Then use te top button to adjust the minute hand and te bottom button to adjust the hour hand, and bring them both, one on top of the other, over the 12 o'clock position. Once this is set, press the middle button again. This should to the trick.
