I have an older air cooled 3.5 clinton boat motor...probably from the 60's. What kind of fuel mix is needed? Thank you. Tom K.
    President:
  • 3,085 Answers
3:1 mix.
Posted on Jun 26, 2009
1996 mercury 60 horse 3 cylinder 2 stroke
problem in the idle settings of the carby
could be rubber bits from deteriorating rubber hoses /water in the circuits but it needs attention from accredited mercury service centers
Apr 25, 2017 | Mercury Boating
2 stroke oil mix chart
not to my knowledge but if you mix some new and look at it you might get real good idea.knowing what motor the old mix was for might tell you but the best thing to do with it is put in something that run on diesel and pour it in that tank. most a little gas will not hurt them
Sep 08, 2014 | Light Outboard Motor Boat Bass Fishing...
Mercury boat motor troubleshooting
Could be a fuel issue. You don't say how old your motor is, but if it is 10 yrs or older, there is a good chance it does not process regular highway fuel very well. Too much ethanol. Makes the fuel separate after warming up. Your engine will normally start fine, but after getting warm, will either stall out at low speeds, or won't start after shutting down. Try a good additive to reduce the ethanol effect. Most boat docks with fuel pumps also sell the needed blend of gas for marine engines. Thus, a few more cents per gallon, but less problem for you. I mixed a good additive to my 20 yr old Johnson 115, and it runs like a new one! Hope this helps. Good luck !
Skip
Aug 13, 2014 | Boating
What type of gas to use in a craftsman edger 358.773110
FUELING ENGINE This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality 2-cycle air*cooled engine oil. We recommend Craftsman brand oil. Mix gasoline and oil at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). DO NOT use automotive oil or boat oil. These oils will cause engine damage. When mixing fuel, follow instructions printed on container. Once oil is added to gasoline, shake container momentarily to assure that the fuel is thoroughly mixed. Always read and follow the safety rules relating to fuel before fueling your unit.
Sep 12, 2011 | Craftsman Garden
My 1999 150 hp Johnson outboard skips at idle and started stalling at wake speeds. Was running fine until I tried it out for first time this year.
Fuel mix is a common cause of this kind of performance. Take special care to follow the manufactures instructions on fuel mix, most modern outboards run on100 to 1 while it is easy to continue an older mix like 50 or 33 to 1. Sometimes the mix is written on the engine cowl.
Cheers, Timo
Apr 21, 2010 | Boating
Mini mac 35. need to know the fuel/oil mix ratio.
Use 40:1 mix. Be sure to use chain saw engine oil designed for this service, not boat motor oil. Premix the fuel/oil, not in the saw fuel tank itself.
Jan 28, 2010 | Garden
I have a 1993 2 stroke 40 hp mercury outboard motor and it seems that whenever you start it you need to use the choke, even when it's been running for some time and warm. Is that normal for these motors?...
Use it .It is a common thing with 2 strokes.Outboards have water in them and cool down quicker than say a 2 stroke motorbike. They have no water and keep the heat in the engine longer.If it runs well,,don't spend the money.All the choke does is gives the motor a slightly richer air/fuel mix at startup.It cannot hurt the motor.Hope this helps
Jan 05, 2010 | Boating
I have a 1979 Mercury 50 Thunderhead Motor that I Purchased. It was shut off in good working condition about 6 yrs ago. Before I restart it What are somethings I need to do to make sure i don,t damage it?
Ok a few things you probably need to do to protect it...
1. Make sure you use fresh fuel in the tank before you restart it.
2. Make sure you have 2-stroke oil pre-mixed into the fuel (assuming... It wouldn't hurt adding a little more than what is recommended for the motor for the first tank as the oil is your primary protection for the motor).
3. Check fuel lines are all secure, not cracked or damaged.
4. Might be worth looking over the carburettor too. If the carby was run dry of fuel before storage, you might be ok. If fuel was left in it, then the carb will probably need disasembling and cleaning as the fuel in it has probably gummed up or varnished which will cause poor starting and running.
5. It is important to install a new water pump impeller. After 6 years of storage the current rubber impeller has probably dried right out and will be very prone to cracking and damage. Since the impeller is the only part that pulls cooling water through the engine, this needs to be in full working order as poor flow or no flow of cooling water around the cylinders will quickly cause engine overheat and bad engine damage.
7. Check spark plug condition... Probably worth replacing just so you know they are good to go!
That's probably about it for the first start... Just monitor everything as normal after you have it started or are running it in the water for the first time.
If you are happy with the information, please rate my response on FixYa!
Mar 22, 2009 | Boating
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 | Boating
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
