Question about Beckett Water Gardening Beckett Corp 210 Gph Small Pond Pump
Need help taking apat pump.
Aside form smashing my pump's (made by beckett, versa gold series model G325AG20) outer shell to smitherines I can't figure out how to even get it open. Does anyone know how?
    Problem Solver:
  • 10 Answers
Better see a trained service personnel
Posted on Jun 25, 2009
Kenmore Elite H3 washer's loud in spin cycle & smells burnt.Debris & plastic in well inside washer.Pushed aside rubber ring & saw lg. gap btwn. metal drum & surrounding plastic.Parts needing replace?
It sounds like the drum has broken from the rear mount. This will chew up the outer shell. This is a very labor extensive job. The parts are expensive also. You will probably need a new outer shell and inner drum.
May 29, 2015 | Kenmore Washing Machines
Where sale a impeler for beckett w3500.
http://www.homedepot.com/p/Beckett-3500-GPH-Submersible-Waterfall-Pump-W3500HD/100024869
Or if Home Depot can't help you in ordering an impeller for a pump they carry, try sending an email directly to Beckett and ask for assistance on where to get one...
customerservice@beckettpumps.com
Good Luck
May 09, 2014 | Beckett Corporation Beckett W3500 7114310...
Beckett # W1150 WTRFall/Str Pump: Our pump will run for an hour or so, and then it s...
This same symptom happened to me.Check the impeller, if you can pull it out or it just sloshes around in the well housing, then the impeller lock has come out of it's place. Simply pull off the outer intake grill, then twist off the outlet housing. Now you can see that white notched washer and how it must be seated and aligned. Once seated in place use a small screwdriver to turn and lock it in. Now you will see your impeller shaft is no longer loose.
May 17, 2010 | RTO Beckett # W1150 WTRFall/Str Pump
Where can I find a replacement impeller for a 10 year old beckett water pump? The only model information I have is "798" stamped on the out side of the casing.
I'll bet you need to buy a new pump.Most pond pumps from Beckett are sealed and the impeller can't be or should not be changed.
Sep 27, 2009 | RTO Beckett # W1150 WTRFall/Str Pump
I need an impeller housing (part no. CX1777) for a Beckett Versa Gold G325AG20 pump.
The web site for "Otimus home" will get you in touch with more parts than most sites. This site is for pool parts they also have a site for spa and smaller pond equiptment.
Aug 20, 2009 | Garden
My Maytag washer has a defect, technican told me, that lets water get between the tub and outer lining and sit there and stagnate smelling terrible.
The water always goes from the tub to the outer shell, that is where the pump connects. Put a little bleach in the tub with some water, shake the agitator side to side to move the drum enough to circulate the bleach around the tub. Then pump the water out and then lower the hose down to a bucket to get the last of the water out. Feel around between the inner and outer drums for anything that has jumped out of the inner tub to the outer drum. You should be able to push the inner drum aside enough to get your arm in. You may have to open the top to get your arm in the space.
http://www.pcappliancerepair.com/model-display.php Check this site for your machine.
May 07, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I moved my washer cause of relocating and now when on spin cycle it makes a howling noise, what can i do to fix the problem, its a front loader gallery series??
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 05, 2009 | Frigidaire Washing Machines
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Beckett Water Gardening Beckett Corp 210 Gph Small Pond Pump Logo
452 people viewed this question
Top Beckett Water Gardening Garden Experts
Morne Olivier
john h
Craig Butler
Craig Butler
Are you a Beckett Water Gardening Garden Expert? Answer questions, earn points and help others
