Question about OKI C5150n Led Printer
Oki 5150 color are not print right
When I print color pictures there are pink & green streaks I just replaced the yellow and the black drum. Usage menu says
y,m,c toner all say 5k=6% 3k=10%
K toner 5k=100% 3k=100%
Fuser life remaining 68%
belt life remaining 70%
y & m drum life remaining 10%
c drum life remaining 22%
K drum life 99%
    Champion:
  • 331 Answers
You need to replace the magenta drum. Just because there is life left; it's possible it is scratched. Also, take a cotton ball dip in alcohol and wipe the LED's off when the cover is open; those black things that are hanging down from the cover. Also, make sure your drums are installed in the proper spots (magenta in magenta slot). If the toner "rubs off" after it prints... then the fuser is defective.
Posted on Jul 23, 2010
C252 streaks
Check your consumables. Press utility then check consumables. If anything is at the end of life, it needs replaced. It sounds like your drums are not cleaning properly and need to be changed. If they are fairly new, then I would suspect the transfer belt. If you know hoe to get into service mode you can go into test mode. Then run your halftones on each color. If it moves around, its your drums. If it stays in one spot, its your transfer belt. Also you could check your drum units. If they have streaks going across the green drum, like its dirty, then its coming from the drums.
Apr 17, 2014 | Konica Minolta bizhub C450P Laser Printer
The blue color is not printing correctly. It comes out sort of pink and greens are yellow. I have a new balck drum. I have put in a new blue toner cartridge. I have tried adjusting color saturation. ...
create a doccument with four identical lines of text.
the text should be as follows:
your text in the colour Black, the cyan, then yellow then magentta
see if they print in the colours you used, if they are all wrong then delete all drivers associated with the printer and delete the printer, then follow the install proceedure again to reinstall, if just one colour is wrong the it is most likely a deffective cartridge.
Dec 06, 2013 | OKI C5100n Laser Printer
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
Okidata c9650 printer. technician told me to replace transfer belt in my unit because i was having an issue with the color print quality. It had a light streak running through it and the top of the page...
That message is indicating that you need to replace the black drum which also may have been what was causing your origanal issue. Whenever you have a print quility issue print four seperate documents each document using one of the four colors (black, yellow, magenta, cyan)used by the printer. If the problem only shows up in one color then that is where the problem is coming from.
Jan 21, 2011 | OKI C9650HDN Led Printer
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
Oct 08, 2009 | OKI C5200n Laser Printer
Colors are not printing the acutal color
It all depends on the meaning of 'not properly'.
Try creating a document with four different squares, or words, of these colours: yellow, magenta, cyan and black. If all of them print (albeit not with the correct shades) it is probably an ICM driver error. But my guess is that only one of those four colors will print badly, due to a defective color cartridge.
The OKI 5150 makes all perceivable colours using cyan, magenta, yellow and black toners, so if one of these malfunctions, the resulting colors will lack the required shade of, say, yellow, and will appear to be "wrong". The yellow colour itself, of course, would simply disappear (the "yellow" you use might actually be 95% yellow and 5% cyan; then the "yellow" square will be printed as a very light shade of cyan, while the other colors - say, 95% magenta and 5% yellow - will turn out almost exact).
Try with the color test and replace any failing cartridge; if all four (almost) pure colours do print incorrectly, it's unlikely to be a cartridge problem, and we'll have to dig deeper.
Sep 09, 2009 | OKI C5150n Led Printer
My Oki 5150 leaves an unprinted streak when printing in black
If you open up the lid, look for the four led heads, clead them with a dry soft cloth. If problem persists look at the black drum to see if theres any clue there.
Jul 10, 2009 | OKI C5100n Laser Printer
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
OKI C5150n Led Printer Logo
781 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
