Question about Ricoh Office Equipment & Supplies
I need to print tabs on my pro 1106ex and the machine is not letting me complete this. I can run the five tabs through but it is only printing the first tab.
  • Ricoh Expert
  • 398 Answers
Your printing or coping? If printing somthing about a xl spreadsheet and putting the print in all 5 tab positions.
Posted on Jun 28, 2009
My yellows ansd greens are switched
there are a number of possible errors here.
have the machine align its printheads
then have the machine complete colour calibration ( you will need good working printheads to complete the calibrations
when this is finished have the machine print out its config pages and demo print page ( you can find how to do this in the online user manual) this is done to Isolate the printer from the fault - if The demo page and config pages are printed correctly then the error lies external to the printer ( the software printing the document)
OR
check to see if the correct printer driver is installed (to be sure uninstall then re-install) open the driver and check to see in Preferences/colour that the settings are 'let machine decide colours'
or set to adobe pdf. print out the test page from the driver and pay close attention to the windows logo at the top of the page- it should match that on the windows start screen
if you can see that the green yellows are still out of calibration then you may need to change the printheads ( CYAN/Yellow) as the error may lie internal to the printhead.
at the end of the day the fault lies most likely with the software setup or the printheads.
Jan 18, 2014 | HP Officejet Pro L7480 All-in-One...
Xerox 3550 toner install
Replace the print cartridge using the following instructions:
1. Release both latches on the side of the front door and open the door.
2. Pull the print cartridge out.
3. Remove the new print cartridge from its bag.
4. Slowly shake the cartridge five or six times to distribute the toner evenly inside the cartridge. It will provide maximum copies per cartridge.
Note: If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
CAUTION: Do not touch the green underside of the print cartridge. Use the handle on the cartridge to avoid touching this area.
5. Hold the print cartridge by the handle and slowly insert the cartridge into the opening in the machine.
6. Tabs on the sides of the cartridge and corresponding grooves within the machine will guide the cartridge into the correct position until it locks into place completely.
7. Close the front door. Make sure that the cover is securely closed.
Nov 22, 2012 | Xerox 3550 AllInOne Laser Printer
How do i change an ink cartrige in a canon 160 printe
The Canon Pixma inkjet printer is an all-in-one printer, scanner and copier capable of printing high-resolution photos. One handy feature is a slot for a memory card so you print photographs directly from your camera. It can also print completely without any border for full-sheet photos. Printing photos and other high-fidelity documents uses up ink more quickly, and you will probably need to replace at least one of your cartridges every three to six months, a process that should take you about three to five minutes.
1.urn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
2.Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
3.Pull out the used ink cartridge by pulling straight up from the print head, and dispose of them safely and carefully by putting them in a sealed bag.
4.Remove gently any packaging from the new ink, after giving it a few shakes. Pull off the protective tab on the cartridge, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
5.Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
Sep 06, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My hp officejet pro L7580 is connected to DOT4 port, there's a hp officejet pro L7580fax connected to USB002. I want officejet pro L7580 connected to USB002, NOT the L7580fax. My desktop is not...
To walk you through I'd need to know the OS you are running, but the generic answer is that you need to go into the print driver, and in the Printer Properties, under the ports tab , select the USB002 port rather than the DOT4 port and Apply the changes.
Mar 18, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Photos come out totally blurred with colors mixed. Happens on all sizes of paper (photo quality).
  1. Make sure that there is letter, A4, or legal unused plain white paper in the input tray.
  2. Touch Setup on the display.
  3. Touch Tools .
  4. Touch Self-Test Report . A self-test report prints. Figure 1: Self Test Diagnostic Pagec01154260.png
  5. In the Print Quality Pattern section on the test page, look at the color blocks for any lines. Figure 2: Print Quality Patternc01154261.png
  6. If there is no color bleeding in the Print Quality Pattern color blocks, print a document to determine if the issue has been resolved.
If you have completed all of these steps and are still experiencing a problem, continue to Step three. Step three: Check the paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
If you have completed all of these steps and are still experiencing a problem, continue to Step four. Step four: Check the printer settings
  1. In the software program you are trying to print from, click File and then click Print . The Print window opens.
  2. Make sure that your printer is selected and then click Preferences . The printer Preferences window opens.
  3. Click the Printing Shortcuts tab.
  4. The Printing Shortcuts tab lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab:
    • General Everyday Printing
    • Photo Printing-Borderless
    • Photo Printing-With White Borders
    • Fast/Economical printing
    • Presentation printing
    • Two-sided (Duplex) Printing
    NOTE: These general printing shortcuts have pre-selected settings.
  5. To change the settings from the ones that are available on the Printing Shortcuts tab, click the Features or Color tab. Options on the Features or Color tab include:
    • Print quality : If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches your paper type exactly, select it rather than Automatic.
    • Paper size : Make sure this matches your paper.
    • Print in Grayscale : Print a document in shades of gray.
    • Orientation : Specify how the document is positioned on the page.
    • Paper Source : Select the tray that you want to use for printing.
    • Two sided printing : Print on both sides of the paper.
    • Color Management : Specify the color space that the printer will use to interpret image data.
    • Pages per Sheet : Specify the number of pages of the document to print on each sheet.
If you have completed all of these steps and are still experiencing a problem, continue to Step five. Step five: Clean the printhead
NOTE: Do not clean the printhead unnecessarily because this wastes ink and shortens the life of the ink nozzles on the printhead.
  1. Make sure that there is plain white paper in the input tray.
  3. Touch Tools .
  4. Touch Clean Printhead . The HP All-in-One cleans the printhead and prints a test page.
Step six: Service your productIf you have completed all the steps listed above and are still experiencing a problem, service the product
Dec 07, 2010 | HP Photosmart C8180 All-in-One InkJet...
WHEN TYPING A HALF SPACE IS SKIPPED OCCASIONALLY AND WILL NOT CORRECT THE LETTER TYPED, IS THE LETTER WHEEL REPLACABLE?
To answer your question yes the print wheel can be changed, BUT that is not your problem. The machine needs to be reset or the reset tab needs adjusting.
Background;
When you turn on the machine the print head moves to the right side, the print wheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
I would
  1. Power it off and then turn it back on and test to again.
  2. If it's still typing the wrong or unreadable letters then turn off the power open the lid. On the bottom of the case there is a metal frame on the right side of the frame you will see a small metal tab pointing towards the print head.
    1. (When the machine resets its self, it uses that tab as a reference.)
  3. That tab is easily bent which causes the reset to be wrong. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It doesn
Nov 30, 2010 | Brother EM-430 Typewriter
HOW TO PRINT MIRROR IMAGE ON HP 7590
When you are ready to print do this:
1) Select Print from the file menu, on the page you want to print.
2) When the HP Officejet Pro L75XX Document Properties Box opens select advanced from the tabs at the top.
3) Open the tree under "Printer Functions" or if its already open select "Mirror image" and toggle the on/off selector to turn on the Mirror image function. You are done!
4) Return to the Printing Shortcuts tab to complete your selections for this print project.
Note: Remember to reset this function to Off so you don't waste a lot of paper printing something you can't use...
I hope this helps you.
Sep 30, 2010 | Office Equipment & Supplies
How to print auditron report (copy) from workcentre pro 128? Need step by step instructions- have no manual
Printing Service Reports
1. To access Service reports, follow the Entering UI Diagnostics procedure.
2. After entering the Access Number, press the Machine Status button on the Control
Panel.
3. Select the Billing Meter/Print Reports tab on the display.
4. Press the Print Reports/List button.
5. Press the CE button.
6. The following reports can be printed.
• Debug Log Report
• HFSI Report
• Jam Report
• Shutdown Report
• Failure Report
• Protocol Monitor Report
7. Select the required report and press the Start button. The selected report will be printed.
Jun 11, 2010 | Xerox WorkCentre Pro 123/128 Printer
Good Morning, We have the Ricoh Pro 1106EX Copier. Is there any way to print more than 10 booklets at a time? Any way to increase the amount? Very time consuming to stand and remove booklets all day....
the problem is that the finisher youhave can only hold so many copies the sensor that indicates the tray is full is stopping the run. yu might be able to put the switch up and then tape it in place but you will still have to take the booklets out some time..
Jul 29, 2009 | Ricoh Office Equipment & Supplies
I have a PDF file of 145 pages, it requiers 9 Chapters to be printed and inserted into the document, but I can not seem to get the main paper draw to start print job. It says I have not selected Paper...
well usually in corporate printer you have to specify the paper source, if you have selected it and no happened, you may try other tray to put your paper on. if this should not work you may reset the printer by leaving it off and unplugged from the power outlet for at least an hour or 2
Aug 12, 2008 | Ricoh Office Equipment & Supplies
63 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
