Question about Dell Vostro 1500 Notebook
My Vostro 1500 will not turn on anymore...help please!
Last week I got blue and black screens upon start up prompting a safe mode and new configurations. At first I ignored them and chose to Start Windows Normally. Then the blue screens appeared with memory problems and warnings. Now my computer will not start. When I press the power button the power icon lights up, the caps lock icon flashes, then they both turn off. I have tried the Fn solution and various other troubleshoots including removing the battery and AC adapter, but none have worked. I just want my laptop to turn on again.
  • 30 Answers
Reset/replace the Ram/memory. Sometimes faulty and failing ram can keep a computer from booting up. If you have 2 sticks, take one out and then try to boot, then try with just the other stick. The flashing caps lock icon means a general failure, though it is most commonly associated with the motherboard.
Posted on Jun 25, 2009
  • vbermudez Feb 09, 2011
    This recommendation worked for me. I had the Caps Lock "A" blue light blinking, one of the memory sticks was causing it, I caught it by swapping them around trying all combinations. NOw I am running with just 1GB until I buy a new one.
There is a stick of RAM under the keyboard, take it out, reseat, etc./
Posted on Mar 10, 2010
  • lromano696 Mar 10, 2010
    remove the keyboard, there is another stick of ram under it
I had the same problem, there was some moisture on the RAM stick under the keyboard which caused some corrosion across the data lines. I clean the corrosion off and the machine booted up and worked fine after that.
Posted on May 27, 2010
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
Dell Vostro 1500 Laptop:my laptop is no longer going beyond "microsoft corporation" screen with the green progress bar
It sounds like there is a file or files in either your boot files or system files that are missing or corrupt.
Have you tried booting in safe mode? Turn off the computer, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option and see if it boots up. If it does Click Start/Programs/Accessories/System Tools/System Restore. Select a restore point (date and time) that is before you started having this problem. Let it run and then see what happens. If it does not resolve the issue then: (see below)
You'll need a system disk to get around this.
Put the system disk in the cd drive and boot from it. You want to get to the Dos Command Prompt (black box with white lettering) so that you can type the following command: chkdsk /r
Check Disk will run for well over an hour. You will notice the percentage of completion going from high to low, but that is normal. Let it run to completion then reboot.
In windows xp you can get to the command prompt by selecting Repair when the options come up. You'll be doing a repair to the Windows Operating System. Most times you select it by entering a 1. Most times the Administrator password is blank so just press enter.
In Vista you will have to get to the Recovery Console and the command prompt will be down at the bottom
Mar 22, 2012 | Dell Vostro 1500 Notebook
I forgot my password in my pc dell vostro 1015 and i have no sollution plz help me to overcome this problem
Step 1: Enter Safe Mode
a) Start or re-start your computer.
b) Before the Windows 7 loading screen appears, Press 'F8? to enter Advanced Boot Options.
c) Use arrows to choose 'Safe Mode' when you can see the Advanced Boot Options screen.
d) Press 'Enter' and wait for Windows 7 files to load.
e) Log on with an administrator account when you can see the log on screen
Note: Well, when you are presented with the Advanced Boot Options screen, there are 3 types of Safe Mode. They are the Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt, and the 3 options are all available for you. Here above we take Safe Mode as an example, but if you choose Safe Mode with Command Prompt, you'll need to input related to command prompt to reset the password.
Step 2: Reset the forgotten Windows login password in Windows 7
Now you could diagnose and solve some serious computer problems in the safe mode and reset the forgotten Windows login password in Windows 7 as follows:
1. Click 'Start' button, input 'lusrmgr.msc' into the Search box and press 'Enter'.
2. In the 'Local Users and Groups screen', click 'Users'.
3. Right-click the account that you need to reset the password for, and then click 'Set Password'.
4. Type and confirm the new password, click 'OK'. (You can go to 'Local Users and Groups' screen by right-clicking 'Computer' to select 'Manage' on desktop.)
Step 3: Log on your password protected PC again with the new password since you have successfully performed Windows password reset for Windows 7.
Jul 17, 2011 | Dell Vostro 1500 Notebook
When Power On, the computer appears to be starting, get DELL logo, then black screen, then "We apologize for the inconvenience. Windows did not start successfully. A recent hardware change or...
Hi
You didn't told us, what is the most recent updates you've done, i.e.: installing driver or software, or something like this.
Choose 'Last Known Good Configuration', if not worked, choose 'safe mode'
Please tell us your results
Good Luck
May 13, 2011 | Dell Vostro 1500 Notebook
Vostro 1500 Will Not Start
I think that you would have a hardrive issue find out if your laptop uses an ata drive or an sata drive and i would look into getting a new one. if you have any further questions you can email me at jadenb333@gmail.com
Jun 24, 2009 | Dell Vostro 1500 Notebook
My HP TC 1100 tablet PC comes up to a black screen offering me choices of "Safe Mode", "Safe Mode with Networking", Safe Mode with Command Prompt, "Last known Good Config" and "Start Windows Normally". Any...
There is a problem with the OS.
Try re-installing it.
If it still doeasnt solve the problem, then there is a problem with your hard drive.
Thank You
Please rate my solution
Jan 14, 2009 | Microsoft Windows XP Professional With...
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
HP Pavilion DV2000
Did you try to do a F8 or F12 and safe mode start, or you can also start from last known good configuration too. Try that out and I hope it gets you up and running,
If you need anymore help just write back here and we will see what we can do. thank you
Feb 07, 2008 | Computers & Internet
Dell Vostro 1500 Notebook Logo
1,908 people viewed this question
Alun Cox
