Question about PC Desktops
MEDIA CENTER I ripped a cd it,s playing the track but I don,t have any sound.
    Problem Solver:
  • 5 Answers
Check your speaker cable it is connected or not and I want to know that Sound is not coming when you play the cd or Sound is not available in ur system, If everything is ok then try to rip the cd again from window media player
Posted on Nov 07, 2007
    An expert who has answered 500 questions.
  • 508 Answers
Hi! White Dove,
First things , first, check the cables in back of your computer, and see if cables are in the right order, green, pink or orange, and blue, and put the cable speaker in the green one, also check if you have the right drivers for your sound card, and is not place in mute on the task bar.
hope I can help!
Posted on Nov 06, 2007
0 characters
3 Points
How to change rip a CD
Windows Media Player will rip it for you. When you open Media Player look at the top of the window and one of the options in the middle says RIP. If you don't have Windows Media Player 11, then go to Microsoft's website and download it.
Get onlineand got to In the google search box type: "Download Windows Media" (without the quotes). Download it from Microsoft's website, so make sure you notice which site it says you are downloading from.
May 11, 2012 | HP PC Desktops
How to Play iTunes Music on Windows Media Player
There's a good chance when you buy music from the iTunes Store that the files that you download will be copy protected by Apple's FairPlay DRM system. It's a great system that protects the rights of the artist and publisher by making it difficult for the consumer to distribute copyrighted material. However, DRM can also be very restrictive by stopping you playing legally purchased music on your MP3 compatible hardware. So, what happens if you want to play your DRM'ed music on a non-iPod?
This tutorial will show you a way to produce DRM-free music that doesn't require any special software that you would normally need to buy. All you'll need is the iTunes software, and a blank CD (preferably a rewritable (CD-RW)).
Before we begin, check for any updates that are available for your iTunes installation, or download the latest version from the iTunes website。
Configuring iTunes to burn and rip an audio CD
CD Burner Settings: In order to set up the iTunes software to burn an audio CD, you first need to go into the settings menu and select the correct disc format. To do this, click on the Edit tab on the main menu and select Preferences from the menu list. On the preferences screen, select the Advanced tab, followed by the Burning tab. First, make sure your CD burner is selected from the drop-down menu alongside the CD Burner option. Next, Select audio CD as the disc format that is to be written by your CD drive.
CD Import Settings: While you are still in the preferences menu, click on the Importing tab to access the CD ripping settings. Verify that the On CD Insert option is set to Ask to Import CD. Next, set the Import Using option to a format of your choice; the MP3 Encoder is your best choice if you want to import audio CDs as MP3 files that play on virtually all compatible devices. Choose an encoding bitrate from the Setting option; 128Kbps is the normal setting that is good enough for the average listener. And finally, make sure the Automatically Retrieve CD Track Names From Internet and Create File Names With Track Numbers and both checked. Click the OK button to save your settings.
Making a custom playlist
To be able to burn your DRM copy protected songs to audio CD you will need to make a custom playlist (File > New Playlist). You can add music tracks to a playlist easily by dragging and dropping them from your music library to your newly created playlist. For instructions on how to achieve this, why not follow our tutorial on How to Create a Custom Playlist Using iTunes.
While creating a playlist, make sure that the total playing time (displayed at the bottom of the screen) doesn't exceed the capacity of the CD-R or CD-RW you are using; typically, the total playing time of a 700Mb CD is 80 minutes.
Burning an Audio CD Using a Playlist
Once you have created a playlist, simply left-click it (located under the playlists section in the left pane), and then click on the File tab on the main menu, followed by Burn Playlist to Disc. The CD drive tray should now automatically eject so you can insert a blank disc; ideally use a rewriteable disc ( CD-RW) so you can reuse it multiple times. Before iTunes starts burning the DRM protected songs, it will remind you that creating an audio CD is for your own personal use only; once you have read this notice, click on the Proceed button to start burning.
Ripping an audio CD
The final step in this tutorial is to import (rip) the songs that you burned onto audio CD, back to digital music files. We have already configured iTunes (step 1) to encode any audio CD that is inserted into the CD drive as MP3 files and so this stage of the process will be mostly automatic. To start ripping your audio CD, simply insert it into your CD drive and click the Yes button to start. For a more in-depth look at this process, read the tutorial on How to Import CD Tracks Using iTunes.
Once this stage is complete, all the files that have been imported into your music library will be free from DRM; you will be able to transfer them to any device that supports MP3 playback.
Note:The only downside in using this method is that if you have a lot of files that you need to convert, then it ends up a slow and tedious process. With this in mind, use a legal drm removal tool if you have a large quantity that you need to convert.
on Aug 25, 2010 | PC Desktops
How do i put songs on my xbox
Follow these steps :
Burn CDs. The easiest way to put music on your Xbox 360 is to rip CDs from your own collection. Simply insert your favorite CD in you Xbox 360 and then pull up the secondary menu with the Xbox logo button. Then select "Rip CD" from the menu to transfer the tracks from the CD to your Xbox hard drive.
Sync your computer with your Xbox 360. If you have Windows XP Media Edition or Windows Vista (any edition) and a wireless connection your computer will be able to detect your Xbox 360 and can share media with it. Simply find the "Windows Media Extension" tool on your PC and follow the prompts to stream video to your Xbox 360.
Nov 20, 2010 | PC Desktops
Windows Vista Premium. Trying to rip a cd to my computer. Unable to do so. CD plays fine if i play music from the cd itself. Tried Itunes 1st. Rips about 12 secs of audio for each song. Says complete....
maybe the windows has this security issues. coz from my point of view windows vista is dedicated on security. so that's why you cannot rip most of the songs very well.
Mar 05, 2010 | PC Desktops
I have put a cd onto my computer as a folder how
You will have to convert the audio CD to mp3 before you can load it on your phone. Open Windows Media Player, go to tools (right click on the top bar if the menu is not available), and click options. Under the RIP tab, change the format to MP3 and select the quality you want (suggest middle of slider bar). Click OK and insert your CD. Now click on the RIP tab at the top of Media Player and rip the tracks you want to your computer. After you do this, you can then copy the newly created MP3 files to your phone.
Jan 29, 2010 | Dell Inspiron 530 Desktop Computer
How to change my cd to MP3?
you can rip CD tracks to MP3 using Windows Media Player. Once you have the songs ripped, you can then copy the MP3 files of several CDs to a single CD using Windows Explorer to burn the MP3 files to the CD
Sep 30, 2009 | Dell Optiplex GX150 Tower Computer - 1GHz...
I tried to make an exact copy of a CD via Sony Vaio but the copy is messed up. Certain cuts sound scratched. The original CD is clean and plays normally. Does my CD drive need fixing? It (software)...
What type of CD did you copy? Different CD types have different methods for copying them (Example: a music CD has multiple tracks to copy; better to rip them then reburn them onto a blank disk; a DVD disk has multiple data, video and audio files protected on the disk, a straight copy wont work). Based on your question, you tried copying a music CD. Use a program like Windows Media Player, RealPlayer, or iTunes to rip the disk, then copy the ripped tracks to a blank disk. All three of these programs are free, and there are tons of other free alternatives out there to do this.
Mar 11, 2009 | Sony VAIO PCV-V200G PC Desktop
Can no longer play commercial DVDs on my Microsoft Media Player.
download this >>>>>>> XP codec pack:
install this codec pack, after install reboot the pc and try again, if microsoft media player still gives you grief, open the dvd's and cd's in media player classic, it will be on the desktop
hope this helps
Nov 23, 2008 | PC Desktops
How do I fix a drm problem in windows media player 11
DRM, which specifies whether tracks copied from CDs in Windows Media Audio (WMA) format are protected files. A license, which helps protect the copyrights of artists by preventing unauthorized distribution, is required to play protected files.
If you're trying to play your copy-protected files on a new computer, you can migrate your protected music from one computer to another by doing the following:
Windows Media Player 7.1 or later
Try to play the copy-protected file again.
In the message that appears, click the More Information button.
Follow the instructions for migrating your licenses.
Download the Personal License Update Wizard for Windows Media Player ( follow the instructions.
A license can be migrated ten times. After this limit is reached, you will receive an error when you try to migrate the license again (for more information, see the Windows Media Player FAQ). When this occurs, you will need to rip the file from the CD again.
note.gif Note If you still have the CD in your possession, you can rip the tracks from the CD again, but with copy protection turned off.
May 09, 2008 | PC Desktops
Media player
I know ur cd drive is not proper drive to play musib bye bye
Sep 26, 2007 | Dell Dimension 2400 PC Desktop
PC Desktops Logo
62 people viewed this question
Top PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you a PC Desktop Expert? Answer questions, earn points and help others
