Question about Brother DCP 1000 All-In-One Laser Printer
My brother DPC 1000 is printing a dark background when copying. I have adjusted the contrast and nothing changes.
  • 526 Answers
One of two things, either your drum is bad or your fuser.
one thing you can do to narrow it down, is make a copy and as the paper goes in almost all the way open the door. and take out the drum. some paper should be sticking out past the drum, if you still see the dark background, its probably your drum.
be careful, the toner has not been fused yet.
also, try cleaning the charge wiper by moving the tab left and right
Posted on Jun 26, 2009
What Print unable 0B
brother dpc 1510 printer showing on print unable 0B. how to clear?
May 27, 2016 | Brother DCP-1510 Laser Multifunction...
How to remove dark background on bizhub 350
Make multiple copies of Jet black print for example, open the platen cover and then make blank copies.Print out will be jet black.After about 60 to 70 copies background will be adjusted, if not then replace the toner.After replacing the toner if the background is still there then you must replace the developer.
Feb 11, 2015 | Konica Minolta bizhub Office Equipment &...
How do i change to get copied document to appear
There are 3 settings for print quality on the front panel, good, better, and best. Also when it is set on copy you press the menu button and scroll thru the choices and you will find a contrast setting that you can scroll to a lighter setting.
Jan 29, 2010 | Brother MFC 240C All-In-One InkJet Printer
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Display contrast - too dark
You should be able to adjust LCD contrast when phone is idle, just use the up/down arrow button to adjust it (don't go off-hook). If you have background music set, the above procedure will adjust the music volume instead. You can turn Background music on and off by pressing <Feature>,2,6 when your phone is idle. Alternatively, you may press <Speaker> 6,0,2 and then use the UP/Down arrow key to adjust LCD contrast.
Dec 11, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Toner prints to dark
hi!!!!!
try to re-install the driver of your printer!!!
or try to figureout the settings of your printer
Brother DCP 1000 All-In-One Laser Printer Logo
271 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
