Hello, I have 1996 Ciera with rebuilt engine pretty new, also fuel filter and fuel pump replaced but I have a problem, the car starts and runs well cold but once car has been running for a few hours, either stopping or coming to a stop it starts to idle roughly and has come to a stop at different occasions. Check engine light does come on and off occasionally. Can you help?
usually when the camaro runs rough that could be bad fuel injectors-o2sensor and fuel filter-thats my guess i had the same problem and i put bad gas in and the fuel filter went bad
You say you replaced the fuel pump, what about the filter? If the filter is clogged it can cause this as can ignition. Since the car started for you after the fuel pump was changed the original problem was the fuel pump. But you should never change the pump without installing a new filter.
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
