Question about Westinghouse Televison & Video
I have a 32inch Westinghouse LCD TV that is dim/dark/low light. i can still see the image in shaded areas of the house. whats the problem i did some reasearch on the web and think its something that has to do with either the inverter or backlight. will replacing one of these fix my problem? if not what do i have to do?
    Problem Solver:
  • 14 Answers
I would also say its the inverter board if you have a very dark picture that is barley visible.
inverter board - Dark picture barely visible
power supply - if lcd will not turn on at all
lcd controller - if lcd will turn on but picture fails after a few minutes after being heated up or have scrolling lines threw picture. (try heat sync and thermal paste on lcd processor chip)
Main board - System will not book (less likly but if your components are bent or tweaked it could be a possibility)
Posted on Jun 26, 2009
  • Westinghouse Master
  • 19,396 Answers
You need to replace the inverter board. The lamp failing is very uncommon, moreover LCD Tvs have more than one lamp, and they do not fail all at once.
The connection cable from inverter to main board must be tested, the inverter must be tested, then the inverter must be replaced.
If you DIY remember that the inverter is an high voltage board.
Posted on Jun 25, 2009
The best contrast and brightness settings for a toshiba crt floor model tv,model 50A61
Televisions are unlike other consumer electronics products. Their setup and settings have a tremendous effect on how well they perform. The best TV on the market incorrectly setup will almost always look worse than a mediocre TV setup well.
Ideally, you'll get a setup disc to ensure the correct settings, but regardless, it's important to know what each setting actually does.
To get the ultimate performance out of your TV, a full calibration by an ISF Certified technician is your best option. Even if you go that route, it's good to know what the calibrator is adjusting. So here's a quick look at the basic settings every TV has, and what they do.
Please keep in mind, this is only a general guide in what each setting does, and rough idea how to set it. Correctly setting up a television is a completely different article.
Where to start
Nearly all modern TVs have picture modes. These are labeled things like Standard, Cinema, Vivid, and so on. Cinema or Movie is often the most accurate setting, with all the controls set to offer an image close to what a director intended them to look like. Most people aren't used to an accurate image like this, and to them the TV may appear reddish, soft, and possibly dim. Technically, it isn't. Other picture modes like Vivid or Dynamic are programmed to "pop" on a store sales floor with an overenhanced, blue image. Because most people don't change any of their TV's settings, this has resulted in most people thinking a TV should look blue.
The choice is yours, of course, but we here prefer an accurate image and suggest you at least try it for a few days. Once you get used to it, you'll never go back. Check out What's the best picture mode? for more info.
Regardless, all TVs need tweaking to look their best. Here's what the main controls do.
Backlight
Only LCDs have this control (though not all of them). This is a direct control of how bright the image is. Setting this lower will reduce eyestrain, and save a little on electricity. Before you adjust Contrast to make the image brighter, try here first. Check out LED LCD backlights explained for more on this.
Some plasmas have a control that drives the pixels harder, which in some ways acts similar to a backlight control. Samsung's name for this on their plasmas is Cell Light.
Contrast
Sometimes labeled "Picture." This control makes the image brighter...up to a point. Every television has a maximum light output. Once you reach this point, increasing the Contrast control further actually degrades the image. Correctly set, you would see a fluffy cloud in a bright sky. Set too high, you'd see a blotch of white instead. As mentioned above, try setting the overall light output of an LCD with the Backlight control first (if available). Then adjust the Contrast.
Brightness
This controls how dark the dark areas of the image are, again, to a point. Every TV has a minimum light output. Once you reach this point, decreasing the Brightness control starts removing "shadow detail." Correctly set, you'd see all the detail in a black leather jacket at night. Set too low, and it would be a black area on a black area, probably with a head sticking out of it. For more information on how the contrast, brightness and backlight settings interact, check out my article on contrast ratio.
Color
Can be thought of as color saturation. Setting this too high will make everything look cartoony. Setting it too low will make for an expensive black-and-white HDTV.
Tint
Rarely will you need to adjust tint, a vestigial control left over from the CRT "tube" TV days. It gives a green or magenta shade to the image.
Jun 23, 2016 | Toshiba Televison & Video
Led tv sound but no image, samsung 32inch tv that has a very dim image and only seen in dark when light help up to it.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 18, 2015 | Samsung 5 Series UE32F5000 32" LED TV...
Monitor dims when we turn lights off in room.
You need to give a more detailed description of the problem.
The LG 47LH90 is an LED backlit TV with 'local dimming' technology. This means that there are lots of white LEDs behind the screen and these can be controlled in groups to allow localised areas of the screen to be dimmed to produce better contrast between light and dark. It is very likely that when the room is dark, this local dimming is more noticeable. The actual individual LEDs cannot be controlled and so the area that is dimmed will generally be greater than the area that is required to be dark 'blooming effect'. In addition, LED backlit displays only maintain their contrast through a tight viewing angle. If you sit too farto the right or left, then light from non-dimmed LEDs will leak through and the screen will look lighter.
In short, there may not be any fault with your TV.
Jul 12, 2011 | LG 47LH90 47 in. HDTV LCD
Samsung LN-T4661F with black shaded area.
The back light is beginning to fail, thats why it goes shaded but you can still the picture on one side, do a google search for back lights for your make and model, there a few how to's to help you with changing the back light.
Feb 17, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Dark Shaded Rectangle in the middle
Check the settings for the input and make sure captioning is not on....text mode does this on mine, figured it out after hours of pulling hair out...
Oct 17, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Televison & Video Logo
384 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
