Question about Sony Cyber-shot DSC-W50 Digital Camera
Camera frequently locks out and have to remove batteries to restart
Since purchasing this S 1050 camera it frequently locks out for no apparent reason and then I have to remove the batteries to free the camera, I then have to press the on / off button to close it down then re start the camera by pressing the on button again. This is most frustrating .
SOURCE:
Arpi
  • 326 Answers
SOURCE: Camera does not turn on
Hello, reset in this case is not a solution. Maybe your lens is stuck. For further info please contact me at LIVE session. Best regards, Arpi
Posted on Jun 24, 2007
  • 67 Answers
SOURCE: My camera is not going on, I see a yellow light
Sounds like a battery problem , try buying a new battery or the camera adaptor.The battery unfortunately is faulty and wont charge.
Posted on Dec 09, 2007
SOURCE: sony camera turning itself off...
You can't use regular alkaline batteries in this camera. Alkaline batteries only supply 1.5 volts. The camera uses 2 in series for a total of 3.0 volts from alkaline. However, the camera requires 4.2 volts to operate correctly. This camera has high power requirements, so you'll need high end lithium or nickel hydride batteries that can supply the higher voltage and current this camera requires. It's a power hog, and regular alkaline batteries are too weak to run it. The menus will work on alkaline, but once you try to turn the camera on in capture mode to take a shot, the current requirements to operate the camera motor, LCD, zoom, memory stick, etc, all it once is too great a draw for alkaline to handle. Either use the external power supply, or get Lithium batteries. Make sure the batteries you get are 2.4 volts and not 1.5 volts. Get the ones with the highest current rating you can find.
Posted on Feb 12, 2009
SOURCE: i have a sony cyber shot 6.0 mega pixels. Dsc-S600
ACCESS
Posted on May 23, 2010
tbreeze47
  • 3083 Answers
SOURCE: I get a Camera Error
There are numerous things that can cause a lens error, and none of them good. The camera is almost new and shouldn't be experiencing any of these messages. You should contact Sony support and see what can be done. Here is their support site:
http://esupport.sony.com/
If they can't help you resolve this, and won't honor any kind of warranty, the following site details things you can try to correct this problem:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
There are tiny gears inside the lens assembly, and a focusing ring, and any speck of dirt or dust or lint can jam one up, causing a lens error. You can try to spray some compressed air ($4 at Walmart) inside the lens assembly, while it's extended, and hopefully free it up.
Hopefully Sony will help you out, and allow an exchange.
Posted on Jan 02, 2011
What batteries can i use in the samsung af zoom 1050
You will be looking for a 123A battery that you will most likely find at a battery store, or many an electronics store like Best Buy. Or you can google your camera model and order the battery online.
Mar 02, 2015 | Samsung AF Zoom 1050 35mm Point and Shoot...
I have a Olympus Stylus 1050 SW digital camera, How do I download photos to my computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 27, 2012 | Olympus Stylus / mju 1050 SW Digital...
Camera not turning on
Try this:
1, Remove the bateries.
2, Hold down the on/off button for about 45 seconds.
3, Re-insert batteries.
4, Restart camera.
It worked for me.
Jul 11, 2010 | Vtech Kidizoom Digital Camera
Has lock card
To solve the problem, cycle the lock switch on the memory card and try again.
CAUTION Before adding or removing memory, make sure the processing or ready light is not blinking then turn the camera off and remove batteries.
GREAT HINTS Most cameras will reset to original settings if batteries are removed for at least one minute. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
May 30, 2010 | Samsung L100 Digital Camera
Hello Kitty KT7009 camera won't charge!
It could be something more serious, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Aug 29, 2009 | HP Photosmart M425 Digital Camera
SCREEN IS STAYING BLACK WHEN I TURN ON CAMERA?
Remove the battery .. and put back .. and still doesn't works . then please show it to the dealer
Jun 06, 2009 | DCS Norcent Technologies XIAS DCS-1050...
Hi there, I purchased a Casio Exilim Ex-S880 8.1Megapixel Digital Camera last Christmas. Intermittently the camera just stops working for no apparent reason. The power just turns off with the lens in the...
I'm using a 2Gb card which currently contains about 600 photos.It appears that the camera is having trouble with this quantity. Removing half the photos solved the problem.
May 09, 2008 | Cameras
Camera functions are locked up
Looks like the camera doesn't go out of the post shooting preview. That could be a software problem. Try removing the camera's battery for 3 minutes to clear the memory.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cannot turn on camera
How old is it? If you purchased it through a credit card this is proof of purchase. Wat ever the answer to the above contact the Pentax Tech Support line - this may be a recall issue.
May 18, 2007 | Pentax *ist D Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
46 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
