Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Husquavarna tractor battery won"t start engine
The engine does not start, no indication when the key is turned. The battery is at 12vdc. When jumped, the engine starts. The charging guage never shows a charge when running. When jumper cables are installed, the battery charges at 15 amps. Do I have a dead battery that needs charged, or a bad generator?
Tom
  • 127 Answers
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
Posted on Jun 26, 2009
Merc e320 1997 model,W210 engine wont start. Please help
If you hear a click while turning the key this would indicate low charge in battery any reading under 12 on a tester would have trouble starting other than that loose battery leads have you tried jumping if it starts with a jump this would indicate battery.
Oct 14, 2016 | Mercedes-Benz E320 Cars & Trucks
When trying to start my husquavarna 4824 zero turn mower it does nothing starter does not engage and battery is ok
Check your blade ingage switch. Sometimes they stick. You can jump start it by jumping across the solenoid switch beside the engine. I sometimes have to engage and disengage my blade switch and it starts. Hope this helps.
Sep 30, 2013 | Husqvarna Garden
F150 turn chiped key, but engine won't start jumped star and it starts
Hi Trinity, If the vehicle starts with a jump, the security equipment is working correctly. Have the battery and charging system checked. Regards John
Apr 21, 2013 | Ford Cars & Trucks
John Deere LA140 won't turn. New battery. No sound when I turn the key. No headlights, what should I do?
Check your connections at the battery. May have a bad ground or bad battery connection. Also check to make sure new battery is good by supplementing with a jump start. If new battery is good and connections are solid, you most likely have a broken wire somewhere. The lights may only work with the mower running though. I believe on my LA105 the lights only come on with the engine running and dim/brighten with the RPM of the engine.
Apr 07, 2013 | Garden
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Oct 10, 2017 | Jeep Grand Cherokee Cars & Trucks
Tractor won't turn over. Replaced Battery, starter and hotwire to starter getting smoking hot while trying to jump the tractor or start the tractor.
Is the engine free to rotate? Can you move it by hand? If not, the starter can't.
If so, try removing the plug and starting it.
Gary
Jul 24, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
When I turn key on I get nothing. No lights , no engine hours, no nothing.
If the battery is fully charged you most likely have a blown main fuse. If you can't find it send me the model of the mower and I will try to assist you. Regards Phil.
Apr 26, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
1991 Nissan 240SX starter will not turn!
If you've applied 12VDC to the solenoid and it does nothing, not even click, then the solenoid is toast!
Mar 22, 2009 | 1989 Nissan 240SX
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
766 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
