Question about Campbell Hausfeld PW2102 Gas Pressure Washer
The water pressure going into the pump, coming out is the same pressure as it is going into the pump. Waht is the problem
Why doesnt my powerwasher pump out water
check for a blocked jet in the end of the wand ( squashed hoses or blocked hose to the wand)
the blocked jet has the same affect as not pulling the trigger and the pressure regulator bypasses the water back into the pump
Sep 08, 2015 | Annovi Reverberi RMV2.5G27D Pressure...
I have a 2005 chevy impala with a 3.8 liter and i cwnt get the water pump bolt pass the power sterring pully waht can i do
Remove the PS pump without disconnecting any lines and just move it aside enough to get the water pump out.
Jul 20, 2013 | Cars & Trucks
Well i turn the heat on and wait for the car to heat up and there cold air coming out i put antifreeze and and its still doing the same thing
either you have a clogged core or the blend door or motor is going bad, or have you had any problems with your water pump? try the thermostat maybe stuck, try a nuwone first then see waht happens. Thanks
Apr 08, 2011 | 1998 GMC Jimmy
Last week my electric power went off for about one hour, in my kitchen I heard water rushing out my drains. when the lights came on I had no water.The well man came and said he had to turn my pressure...
It sounds like the bladder in your pressure tank is water logged. Turn your pump off and open a tap and let the pressure off. Once the water has completely stopped coming out of the tap go to your pressure tank and pump air into it. There should be more water come out of the tap. Continue to pump are in until you reach the pressure recommended for your tank and there is no longer water coming out of the tap. Close the water tap and turn the pump back on and this should fix the problem. If it does not you will probably need a new pressure tank. The bigger the pressure tank you have also will make the pump work less. I prefer a smaller one myself as there is less change in the shower pressure when the pump cycles than with a bigger tank but this is just a matter of prefference. Some people prefer a larger tank as it uses less power by the pump not working as often.
Mar 15, 2011 | Plumbing
No water pressure coming from pump
The pump is bad and needs to be replaced. you have done all the test. On the Briggs they do have kits to rebuild the pump on your system you can just go to there website and get the rebuild kit. It is safer to go through them because they have jsut started producing the rebuild kits, and other companies have tried to copy them, but there kits are worthless. Please rate
Jun 04, 2010 | Briggs & Stratton Prosumer 20324 Gas...
No water coming out of the pump
Hi
Is the pump working?
Some pressure washers need to suck the water out of a container, not pressure fed from a hose.
Check the filter for blockage.
Regaeds
Phillip
Oct 16, 2009 | Psi 2000 Pressure Washer
Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
259 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
