Question about Kenmore Elite HE4 Electric Dryer
Kenmore Electric Dryer
My dryer work fine and just stopped. No warning! We have checked the thermal fuse, start switch and door switch. What else could it be?
    Sergeant:
  • 288 Answers
Forgive me for stating the obvious, but you didn't say, have you checked the outlet for power coming in?
Posted on Nov 05, 2007
Siemens ultra sense dryer stopped working, found broken belt, replaced belt but dryer still won't run!
-There are couple things that cause a dryer not working:
-Thermal fuse.
-Heater element.
-Timer switch.
-Door switch.
-start switch.
-Or the motor.
Check these components.
Good Luck
Mai
Dec 05, 2013 | Kenmore Elite HE4 Electric Dryer
Push start button wont start dryer
This could be the non resettable thermal fuse has popped, or the door switch is not working. Open the door and press on the door switch until it clicks and push start to see if it works. If it clicks and still no start, then the thermal fuse needs replaced. UNPLUG the dryer, remove the back and you will see the white thermal that looks like a regular thermostat with 2 wires on it. It is located on the air plenum. There could be 2 depending on the exact model, but normally only one white one. These thermals usually pop when the temperature gets too hot as a warning something needs checked. Check your vent and be sure it is absolutely clear, and the flapper on the outside is not stuck with lint buildup.
Nov 27, 2009 | Kenmore 62602 Electric Dryer
Dryer will not come on at all. working fine on last load
check house fuse/circuit breaker
door switch
if an electric dryer the thermal fuse as they are often wired into the motor run circuit
check for power to the motor in start and run circuit, if present motors spent.
if not present trace back to timer and verify timer is sending power, if not timers spent.
more likely circuit breaker, door switch or thermal fuse if electric dryer..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore 64902 Electric Dryer
Dryer just stopped
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
May 31, 2009 | Kenmore Dryers
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Apr 01, 2009 | Kenmore 63942 Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't start due to delay button lights up and won't go off
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
3. Thermal fuse
4. Timer
Nov 09, 2008 | Kenmore 659 Electric Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
