Question about Broan-NuTone CV350 Performance Bagged Central System Vacuum
Replacement of cv-350 model motor and does not vacuum, brown out. i switched black and white codes but same thing. Please help me.
I contacted to MD service technician. He explain, good advise. I follow his directions and cv350 works very good. Power getting as new. Thank you very much.
Posted on Jun 30, 2009
How do you rewire vacuum cleaner motor from the outside of the motor to power button and the retractable cord
I'm going to give this a shot hoping that you don't fry something.
Be careful.
It's just basic wiring.
The motor has 2wires coming out ?
If yes, it doesn't matter which of the incoming Black/White, or Euro Brown/Blue connects to which wire on the motor. The Green/Green with Yellow stripe Ground goes to metal aka ground. Hopefully you can find where the original ground connection is located and put ground there.
You will have to cut ONLY the Black (Brown if Euro) wire at/near the switch.
One end of the cut Black/Brown wire goes to one side of the switch, the other cut end goes to the other side of the switch.
Here's what happens -
With the switch off and the vacuum plugged in, nothing runs because the Black/Brown wire is not allowing a path for current because the switch is off.
When you turn the switch on, the circuit completes. Current flows thru the switch to the motor, out the motor on the White/Blue and back into the outlet..
If something shorts to metal the current will flow thru the metal and into the Green/Yellow stripe wire and into the outlet and trip the breaker.
If you ever take anything apart to repair, the first tool you get is your phone and take pictures of everything.
Feb 02, 2018 | Vacuums
I have a Kenmore Upright Model # 11630412001 with a broken power cord
Normally, you would leave the current power connections attached and then line up or label the new cord lines with the old.
There should be a common ground, easy enough to dsitinguish.
A hot, normally black.
A return, normally white.
These may be swapped it the existing wire colors are.
Red = new black
Black = new white
Green or Blue = Green or bare.
I'm a bit surprised t read your post as the cord should have come with connection instructions if the replacement cord is different in color scheme from the old.
ALWAYS TAKE SAFETY PRECAUTIONS WHEN WORKING ON HOT LIVE POWER. NEVER MAKE CONNECTION CHANGES WHILE THE VACUUM IS PLUGGED IN.
IF AFTER YOU CONNECT THE NEW LINES, TEST THIS BY TURNING ON THE VACUUM AND TURNING IT OFF RIGHT AWAY. IF YOU HAVE POPPED A BREAKER OR SEEN BURNING, YOU HAVE TO SWITCH THE BLACK AND WHITE WIRES.
The best thing is to always go online and find the wiring layout for you model.
If you have any doubt, pleast post the wire colors you do see now coming to the connection terminal and post the colors coming out of your new power cord.
Regards,
Worldvet
Jul 05, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Where is the reset switch on the Nutone CV-350
The reset button to the vacuum unit is located on the upper left or right hand side towards the back. There is a small black circle about the size of a dime that has a white tab that pops out. If the tab is sticking out, you can reset the system and trying vacuuming. Typically, the reset button pops for a reason because of an overheating or defective motor. If the reset button is not popped, try turning on the unit from a vacuum inlet and see if you hear a clicking sound at the vacuum unit. If so, this means a new motor is needed. If a clicking sound is not heard, this can mean a bad relay in the unit.
Please visit our website if you need a replacement part or if you have more questions.
https://qualityhomesystems.com/central-vacuum-system/
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/?ref=hl
Mar 15, 2016 | Broan-NuTone CV350 Central Vacuum
Can't hook up power cord to main motor on Hoover model F5915100
You have a black and white and green wire. Green is ground white is neutral, black is hot . Should say on the motor either L1 = black wire. L2 = white wire , G = Green wire or it say H = black wire, N = white wire , G or the symbol for ground = green wire
Apr 11, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My oreck upright model xl3640 is not turning on. A clothespin was accidently vacuumed up, and the machine was immediately turned off to remove it. The bottom panel of the machine was taken off to remove...
the Oreck XL3640 power switch goes bad most vacuum service center can order a new switch it has 3 wires remove screws from handle to get at switch hook up wires to new switch color code of wires of wires are black white black just put on right terminal on switch _1284.jpg
Mar 08, 2011 | Vacuums
The motor on our Nytone CV-350 is shot. Should I buy a new motor or replace the unit?
It depends on the age and condition of the rest of the vacuum and accessories. Check out the hose and power nozzle especially. If these look well worn, replace the unit. If it's a no more than years old, I'd simply replace the motor. Again, it depends on the condition, or expected "life" of the other components.
Jan 24, 2011 | Broan-NuTone CV-350 Central (Kit) Vacuum
Connecting motor part
Hi Charlotte,  Yes, colour coding of wires is a nightmare, isn't it!? Red and brown both signify "live", and blue and black both signify "neutral".  So you should connect brown to red, and black to blue. I hope this is helpful. If you need more guidance, please post here again and I'll see what more I can do for you. I value your feedback, so please remember to rate my response. Good luck!
Mar 04, 2009 | Dyson DC08 Cylinder Bagless Canister...
Nutone model cv-350 vacuum motor will not shut off. I have to unplug system in garage. I disconnected wire to house vacuum inlets and motor is still running. There must be a reset on the motor. I have...
Mine is the same, and it is the relay welding itself closed. The relay is switched by the low-voltage wiring that connects to the vacuum outlets, and it switches the motor on and off. Mine was welded in the energized position. I have cleaned and filed the contacts on the relay, and that solved the problem for about a week. I suspect the relay contacts were plated, or a worn motor is drawing a little too much current (it is several decades old at this point).
Apr 21, 2008 | Vacuums
Poor suction
Either you have clogged filters, or the motor is weak, you could check the carbon brushes, otherwise replace the motor.
Mar 28, 2008 | Vacuums
Broan-NuTone CV350 Performance Bagged Central System Vacuum Logo
130 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
