Question about Armstrong 1/4" Drive Dial Torque Wrench 0 - 75 in/lb range, 1 in/lb Incr
Would like to know, when setting a Armstrong micrometer type torgue wrench, do you set the lower setting handle to the offset for the number or use the line directly across from number preferred
  • 67 Answers
Use the offset, it is scribed that way so you can better read the number --- you should be able to google up a torque wrench site to verify this
Posted on Jun 25, 2009
I have a accugreen 1000. The wire for the settings has gone slack and I can't adjust the settings. It just stays open. How do I fix this.
You can try to calibrate the spreader, tightening the screw at the end of the control wire should fix the situation. If calibrating the spreader does not help please call us at 800-543-8873 for more assistance. To Calibrate the Accugreen 1000: 1. Adjust the micrometer setting to a 6. 2. Flip the spreader over. 3. Use your foot to squeeze the trigger against the handle. 4. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. 5. To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insect.
Jun 13, 2011 | RTO Accugreen 1000 Drop Spreader
Need to calibrate my Scotts Evergreen drop speader. How do I do this?
To adjust calibration, do the following:
A) Adjust the micrometer setting to 6.
B) Squeeze the trigger against the handle.
C) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
D) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
If you have any questions please the Scotts Help Center at 1-800-543-8873. Stacey@scotts
May 03, 2011 | Garden
I've got a Draper 30357 torque wrench. It says in the instructions that the micrometer should only be turned clockwise. But the wrench needs to be de-torqued when not in use which requires turning it...
Had a look at the manual. From what I can see you turn the handle until the zero lines up with the main divisions and then turn the handle for any additional increments to set the final reading.To do this you have to pick the main reading lower than your intended setting and work upwards by adding increments on the handle by turning it clockwise. You could do this by picking the reading above your intended setting and turn the handle anti-clockwise to reduce the reading but you could make a mistake doing the subtraction. I think this is what they are trying to get across. In any case the handle has to be turned anti-clockwise if you are using the wrench to tighten a nut with a lower torque setting.
Mar 30, 2011 | Hand Tools
How do i calibrate my speedygreen 2000 broadcast spreader
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you need further assistance feel free to contact us @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Scotts& Accugreeen 2000...
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
How do i calibrate the accu green 3000
According to Scott's:
To adjust calibration, do the following: Adjust the micrometer setting to 6. Flip spreader over. Use your foot to squeeze the trigger against the handle. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. To adust alighment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Sep 18, 2010 | Scotts Company Scotts& Accugreeen 3000...
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Armstrong 1/4" Drive Dial Torque Wrench 0 - 75 in/lb range, 1 in/lb Incr Logo
96 people viewed this question
Top Armstrong Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Armstrong Measuring Tool and Sensor Expert? Answer questions, earn points and help others
