Question about Dell OptiPlex GX260 PC Desktop
Dell gx 150
I get six beeps when I attempt to boot the system. after the beeps the system does not boot, nothing happens
thanks chuck
  • chago93 Nov 05, 2007
    R-
    Can't run dell diagnostics. I checked the beep pattern they are as follows: 1 beep, short pause, 3 beeps,short pause, 2 beeps.
    I also checked the error indicators in the back of the unit, the light pattern is A&B are yellow and C&D are green. I appreciate your help.
    thanks!
    Chuck
    Sergeant:
  • 324 Answers
Chuck,
The 6 beeps are an error code. You should note a pattern such as 3 beeps, short pause, 1 beep, short pause, 2 beeps. Also, you may have a set of 4 error indicators on the back of the unit that will show a pattern of green and yellow lights. In any case, you will want to try to run the Dell diagnostics. Let us know the beep pattern and the light pattern and we should be able to give you some more specific information.
R-
Posted on Nov 05, 2007
  • Ron Roske Nov 06, 2007
    Chuck,
    The beep pattern is telling you that you have a memory problem and the light patterns are confirming that you have the same issue.
    Power down your system, reseat your memory modules and try to power it back up. Before reseating the modules, take a look at the contacts and the socket to make sure there is no dust, lint or similar causing problems. Hopefully it will be as simple as that!! If that doesn't work, it sounds like a bad memory module.
    May your day go well.
    R-
Dell optiplex gx 280 beeps 6 times when turnd on and nothing happens
The ram is either bad or unseated. Reme it all and reseat it. If that doesn't work, boot after adding each stick to find which stick or slot is bad.
Nov 11, 2012 | Dell Computers & Internet
Hi, my dell optiplex gx 150 was infected by multiple viruses so i decided to re-install xp booting from cd. after copying all the files from the cd and the pc restarts, its failing to continue installation...
1.You have a corrupted boot sector on your hard drive.
2.you will need to format the drive and then re-install the Operating System.
3. If you are not able to do this then a new hard drive is needed.
4. install a anti virus program after installing the operating system
Feb 08, 2011 | Dell System Board for Optiplex GX 150,...
I have dell optiplex gx 150 beeps 6 times and a and b led is amber and c and d led is green
the 6 beep codes will be in a specific timing i.e. two beeps, a space 2 more beeps, and another space and 2 more beeps.
Looks like it may be a memory problem according to the lights.
ad54556.gif Possible memory failure
Reseat all DIMMs and restart the system to retest.
Here is the link to the beep codes and diagnostic lights for your dell optiplex gx 150 HERE
The Beep codes are in Table 2 and the diagnostic lights are in Table 3.
Apr 14, 2010 | Dell Computers & Internet
Six beeps at post and no joy with boot up
The exact meaning of the beeps for Dell depends on their... rhythm.
http://www.nullamatix.com/dell-diagnostic-beep-code-troublshooting-chart/
Six beeps might indicate a simple CMOS failure caused by a bad battery, which is easy to replace.
Nov 08, 2009 | Dell OptiPlex GX280 PC Desktop
Optiplex wont boot
These file help to boot the system but good news is that you can fix it.through two methods.
1 fix the new boot record using Recovery Console.
2. repair the OS (recommended)
how to accomplish them.
method 1:
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    To repair a Windows XP installation using Recovery Console, press R.
  3. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  4. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
    • on this stage we shall make use of two commands, use one command at ago.restart the computer at every command.
    1. Fixboot writes a new startup sector on the system partition.
    2. Bootcfg modifies the Boot.ini file for boot configuration and recovery.
    Method 2:
  5. assuming method one failed, repent steps 1-4 and -->>press enter to install xp -->>press R to repair. this will repair the entire OS files and you will take the normal installation procedure. incase your stack don't hesitant to email me at arindabosco@yahoo.com
May 08, 2009 | Computers & Internet
Dell Dimension 8400 PC won't boot
http://www.computerhope.com/beep.htm
Here's a list of Boot Codes .....start with one stick of Ram
May 24, 2008 | Dell Dimension 8400 PC Desktop
Dell optiplex Gx 150
This is a problem with your memory.
During POST, the computer checks the computer's memory, determines the amount of installed memory, and then writes to and reads from the number of available bytes to ensure proper operation.
Basic Checks:
  • If an insufficient memory message appears, save and close any open files and exit any open application programs not in use.
  • Consider installing additional system memory.
  • Run the System Memory test in the Dell Diagnostics.
  • Reseat the memory modules.
  • Restart the computer.
If the problem still exists after you complete the basic checks, fill out the Diagnostic Checklist as you perform the following steps.
caution.gif CAUTION: Before you perform this procedure, see "Safety Information."
  1. Reboot the computer.
Does the RAM count displayed correctly match the actual amount of memory installed in the computer?
Yes. The computer needed to update the memory count. The problem is resolved.
No. Go to step 2.
  1. Run the System Memory test group in the Dell Diagnostics.
Did any of the diagnostics tests fail?
Yes. Contact Dell for technical assistance.
No. Go to step 3.
  1. Turn off the computer and peripherals, disconnect them from their electrical outlets, wait at least 5 seconds, and then open the computer cover.
  2. Rotate the power supply away from the system board.
  3. Replace the memory module(s).
  4. Close the computer cover, reconnect the computer and peripherals to their electrical outlets, and turn them on.
Yes. The memory module(s) were defective. The problem is resolved.
No. Contact Dell for technical assistance.
Nov 06, 2007 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
1,127 people viewed this question
Alun Cox
