Question about HP OfficeJet 7310 All-In-One InkJet Printer
Trying to fax out something and it keeps telling me jammed
  • cindy522 Jun 25, 2009
    what shouldI do?
    Problem Solver:
  • 14 Answers
Open up the cover over the adf feed. Make sure there's no paper caught in the mechanism. If I recall correctly (don't have one in front of me), the rollers can be lifted out of this one. Try this and make sure you didn't miss anything. DO NOT FORCE IT. If the rollers don't snap out with only a little pressure, seek another way to pull them out, or perhaops I was incorrect.
If there's no paper, you probably have a stuck or broken sensor flag. The feeds use these flags to detect the presence of paper, so if it's stuck, it's detecting paper when there isn't supposed to be, so the printer thinks you're jammed. If you see the flag and it appears to be stuck, use a stretched paper clip to get it back in place. Again, DO NOT FORCE IT, or you could bereak the flag or the sensor.
If the flag appears to be broken, then you will have to call HP if the unit is in warranty. They do not allow ASPs to work on inkjet printers in warranty and you have to return the unit to them. Often, they will cross-ship you a replacement. Call 1-800-HP-INVENT
Posted on Jun 25, 2009
Lexmark s450 printhead not moving
Try to check for any obstructions inside the printer. Something could be blocking the paper path and the printhead from moving.
Sep 15, 2012 | Lexmark Interpret S405 - multifunction ...
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Printer is not working. I received a fax and something was in front of the hp officejet 4215 all-in-one. the fax came through and was a little crunched up but was just a little wrinkled. It keeps saying to...
unplug the power cord and open the cover make sure there is no paper piece inside just remove the catridge and then plug the power cord and check.
have a nice day dont forget to rate please.
Feb 13, 2010 | HP OfficeJet 4215 All-In-One InkJet...
A paper jammed during a fax. i removed it. now,
When you removed the paper jam did the paper tear? mit have left piece of the orgnial document. Also open document feeder where you place the orginal check to see fot any problem. As for the cover does it look like something on the the door is broke, The actuator on the door Slab of plastic , that goes into a slot on the machine to accurate the door close sensor, if the sensor is not activated then the copier thinks the door is open even if it closed
Aug 26, 2009 | Office Equipment & Supplies
Panasonic UF-890
Take the swinging drum cover off of the toer cartridge and throw it away. It's only for shipping. They come loose and block the paper path.
Put the number you want to forward to in a one touch number position. (if you have to dial 9 for an outside line, be sure to put that into the one touch number also).
Function 74 set 54 set 2 for valid set stop.
Answer to last question, probably...not.
Aug 28, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Faxing
Hi:
You may have removed the paper but the reason why it is still saying paper jam can be caused by at least two things.
If you removed the paper, but it tore while you were taking it out then a small piece could be blocking a sensor or a sensor flag ( a spring loaded finger that the paper has to activate as it moves through the machine) It's possible that a small piece of paper could be blocking a sensor or you may have disloged one of these 'flags' in the area where you first removed the paper. Go back and look closely in that area for a piece of paper or a sticking ''flag'. Until you do that the fax keeps thinking that there is something in the paper path and will keep displaying that message.
Andrew
Jul 20, 2008 | Brother FAX-575 Plain Paper Thermal
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Jul 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Says paper jam, but none jammed
It is probably jammed in the back door of the fax. Check that and see if you find anything.
May 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax says Paper Jam but there isn't one!
After what operation does the machine report the jam. If it is trying to print something and the paper doesn't pull, then it will report a paper jam, even though the paper didn't move. If this is the case then the paper feed tire behind the toner is dirty. Cleaned with rag and rubbing alcohol.
Apr 08, 2008 | Canon FAXPHONE L80 Laser
XEROX TELECOPIER 7024
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Mar 26, 2008 | Office Equipment & Supplies
HP OfficeJet 7310 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
